How to remove lines around hyperlinks
Dec 19, 2016 Dec 19, 2016
I'm using Adobe Acrobat DC on Creative Cloud. I've selected invisible rectangle, but a black line still shows up around the hyperlinked area on the PDF. I can change the line color or type of line, but I there's no option for 'no color'. I previously had Adobe Acrobat Pro and the no color option was available in the dialog box when you first create the hyperlink.
Does anyone know how to edit the setting or delete the lines? Even when I change the color for the line, a black line still shows up.
Edit and convert PDFs
14.5K
Community Expert , Dec 19, 2016 Dec 19, 2016
If you selected "Invisible rectangle" there shouldn't be any line surrounding the link, but you need to make sure to exit the links edit mode by selecting the Hand tool for it to happen.
Dec 20, 2016 Dec 20, 2016
Thanks, that's what it was. I was still in edit mode.
Jan 12, 2024 Jan 12, 2024
How do you set "invisable" as Default ?
Jan 13, 2024 Jan 13, 2024
Set one link as having an Invisible Rectangle and then right-click it using the Add or Edit Link tool and select "Use Current Appearance as New Default".
  1. Open the PDF in Acrobat:
    • Open the PDF document in Adobe Acrobat DC.
  2. Select the Link Tool:
    • Go to the "Tools" pane on the right side of the screen.
    • Under "Create & Edit," select "Link."
  3. Select the Hyperlink:
    • Click on the hyperlink in your document to select it.
  4. Open the Link Properties:
    • Right-click on the selected hyperlink and choose "Properties" from the context menu.
  5. Edit Appearance:
    • In the Link Properties dialog box, go to the "Appearance" tab.
  6. Set Border Color to "No Color":
    • Under the "Border Color" section, click on the color square.
    • In the Color Picker, select "No Color" or set the opacity to 0%.
  7. Click "OK":
    • Click the "OK" button to apply the changes.
  8. Save the Document:
    • Save the PDF document to preserve the changes.
