Hello i modified this script from Trevor to display L*a*b* values. My question is how can i get this to only display 3 numbers after the decimal point?
Right now it displays like below. It would be easier to read if it stopped 2 or 3 numbers after the decimal.
PANTONE 2718 C
L=56.078431372549 a=3 b=-48
// Script by Trevor to make CMYK color Swabs http://forums.adobe.com/message/4890389#4890389
// Altered for L*a*b* Values
var il = app.scriptPreferences.userInteractionLevel;
app.scriptPreferences.userInteractionLevel = UserInteractionLevels.NEVER_INTERACT;
app.doScript("main()", ScriptLanguage.javascript, undefined, UndoModes.ENTIRE_SCRIPT, "Make Lab Swabs");
app.scriptPreferences.userInteractionLevel = il;
function main()
var swatchDoc, doc, swatchColors, l, newSwatch, newSwatchName, cv, ps, m, mtb, tb, ms, tf, ptf;
swatchDoc = app.activeDocument;
setupDoc();
app.activeDocument = doc;
swatchColors = swatchDoc.swatches.everyItem().getElements();
l = swatchColors.length;
while (l--)
if (swatchColors
.name != "None" && swatchColors .name != "Registration" && swatchColors .name != "Paper") {
newSwatch = doc.colors.add ({model: swatchColors
.model, space: swatchColors .space, colorValue: swatchColors .colorValue}); newSwatch.space = ColorSpace.LAB;
cv = newSwatch.colorValue;
newSwatchName = "L="+cv[0]+ " a="+cv[1]+ " b="+cv[2];
newSwatch.name = (doc.swatches.itemByName(newSwatchName).isValid) ? newSwatch.name : newSwatchName;
ps.insertionPoints[0].contents = "\r"+swatchColors
.name+"\r"+newSwatch.name+"\r" ps.insertionPoints[0].rectangles.add({geometricBounds:[0, 0, "15mm", "45mm"], fillColor: newSwatch.name /* appliedObjectStyle: myStyle */});
ps.overflows ? addPages(tf): 0;
function setupDoc()
doc = app.documents.add({documentPreferences:{facingPages:0, pageOrientation: PageOrientation.PORTRAIT}});
m = doc.pages[0].marginPreferences;
mtb = doc.pages[0].bounds;
mtb[0]=mtb[2]-m.bottom;
ms = doc.masterSpreads[0].textFrames.add ({geometricBounds:mtb, textFramePreferences:{verticalJustification:VerticalJustification.CENTER_ALIGN}});
ms.parentStory.properties = ({digitsType: DigitsTypeOptions.ARABIC_DIGITS, hyphenation: 0, justification: Justification.CENTER_ALIGN, paragraphDirection: ParagraphDirectionOptions.LEFT_TO_RIGHT_DIRECTION, contents: SpecialCharacters.AUTO_PAGE_NUMBER});
tb[0] += m.top; tb[1]+=m.left; tb[2]-=m.bottom; tb[3]-=m.right;
tf = doc.pages[0].textFrames.add({geometricBounds:tb})
ps= tf.parentStory;
ps.properties = {digitsType: DigitsTypeOptions.ARABIC_DIGITS, hyphenation: 0, justification: Justification.LEFT_ALIGN, paragraphDirection: ParagraphDirectionOptions.LEFT_TO_RIGHT_DIRECTION, rightIndent: 2};
function addPages(ptf)
np = doc.pages.add();
ptf = np.textFrames.add({geometricBounds:tb, previousTextFrame: ptf});
if (ps.overflows) addPages(ptf);
Thanks in advance.
Chris
Hi Kartik,
that doesn't work at all.
1. colorValue is an array of three numbers
2. Chris wants 3 digits after the decimal point
I would suggest rounding the numbers.
Line 22 could read:
newSwatchName =
"L=" + Math.round(cv[0]*1000)/1000 +
" a=" + Math.round(cv[1]*1000)/1000 +
" b=" + Math.round(cv[2]*1000)/1000;
Uwe
Change line 21 to
cv = parseInt(newSwatch.colorValue);
or
cv = Number(newSwatch.colorValue);
cv = parseFloat(newSwatch.colorValue);
also do the same
Hi Kartik,
Line 22 could read:
newSwatchName =
Uwe
Hi Uwe,
Thanks for the information. Learnt a new thing
Inspect line 22 of the original code.
The index numbers in brackets cv[0], cv[1] and cv[2] point to an array with the value of colorValue.
Uwe
Thank you very much. Works perfectly
