Lightroom 2015.8 lastest update
Engaged ,
Dec 21, 2016 Dec 21, 2016
Hi
Using Mac retinal pro 10.11.6 El Capitan
Just updated lightroom and photoshop to latest update
When 'edit in photoshop' is chosen there is not 'edit in photoshop with lightroom adjustments' anymore
Now images changed in photoshop do not automatically go back into lightroom only to hard drive then needs to
be imported into lightroom
Anyone else having this problem?
523
It is working OK for me on Sierra.
What type of file are you attempting to edit? You won't see the dialog for raw files as they open in PS based on your preference settings for external editing.
Engaged ,
No problems before update so I don't see why a problem now
Have you updated to PS CC 2017 so that camera raw is compatible in both apps?
Engaged ,
yep did that
I can only suggest you try trashing the saved prefs.
-Quit Lightroom
-Press and hold down the Opt(Alt) and Shift keys while launching Lightroom
-Keep the two keys pressed for a couple of seconds after double-clicking (control-clicking) to launch the app or launch by clicking the doc icon if you have one.
-When you release the Opt & Alt keys a  dialog box will appear asking to reset the preferences. Simply click the button “Reset Preferences”
Engaged ,
Thanks will try this tomorrow
When sending a RAW image to PS and both PS and LR are using the same version of ACR you don't get that dialog window asking to send the Original, a Copy or a Copy with LR adjustments. It just sends the file over to PS with whatever.
Check your settings in both the Export dialog window and the External Editing tab of the LR preferences. Also you shouldn't use the Save As option in PS. That stops the image from going back to LR. Just use the Save, Ctrl+s/CMD+s to Save the file.
You will get that dialog window if you send a PSD, TIFF, PNG or JPG to PS.
Engaged ,
Dec 22, 2016 Dec 22, 2016
Thanks for reply
I am sending a CR2 raw image to PS from lightroom
Using your instructions above I used SAVE instead of SAVE AS and it did not give me the option of saving it as a JPEG, only just went into LR as a TIFF
How do I get back my CR2 as a Jpeg in lightroom...should I use SAVE AS for saving a Jpegs and SAVE for a TIFF?
Right that is set by the option selected in the External Editing tab of the LR Preferences. There are only 2 options PSD and TIFF.
You could add a second instance of PS in the second section of the External Editing tab under the Additional External Editor and in that there is an option for JPG (at least on my system there is).
But it you want a JPG from your RAW file after further edits in PS when the file is returned as a TIFF then Export that TIFF as a JPG in LR.
Sure you can use the Save As option in PS and then Import that JPG into LR.
Engaged ,
Thanks 'Just shoot me'....its now making sense
After finish editing in Photoshop simply save & close. Ctrl+S & Ctrl+W (Cmd+S & Cmd+W on Mac)
Go back to LR and select your updated tiff and export a jpeg.
Engaged ,
I want to save it as a Jpeg in LR from PS, not go the time consuming way of having to export as jpeg to get it back in LR
This is when I should use SAVE AS ....yes?
If you use Save As you can certainly create a jpeg but you will need to import it into the LR Catalog from the folder you save it into.
Engaged ,
Thanks thinking I am getting it now
Yes but then you will need to import that JPG into the LR catalog. That is if you want it in the LR catalog. Same time as saving it as a TIFF then Exporting as a JPG.
Both LR and PS are trying to give you the best, highest quality, image file by saving your RAW file as a TIFF. JPG are always compressed and that throws away data.
If you can do all your edits in LR then just export as a JPG without ever going into PS.
Engaged ,
Thanks for being so patient with my query....I think I will adopt this workflow
If you treat the tiff as your master file and export a jpeg from LR you can select “Add to Catalog” in the export dialog. So it is actually quicker than using Save As and importing.
Engaged ,
Thanks, for helping sort this problem
