hi All!
i'm a newbie on illustrator, i read the Illustrator CS6 Programmer's Guide, at pages 27 - Action plug-ins introduce registering action plug-ins events with Tutorial example, but i don't see any Action events showed in action panel. so someone can help me. Thanks!
Actions only show in the panel after they've been recorded. You need to register your action and when your plugin is fired, check if recording is on (AIActionManagerSuite::InRecordMode). If so, you record your action using the AIActionManagerSuite. Then you just listen to the caller/selector that indicates AI wants you to play it back, and you unroll the parameters using the same suite and perform your operation.
thank you, A. Patterson! I did it as your guide, but not get any action. cause is in addAction function do not finish to register action event. you can give an example to me ? thanks so much
During start up, you need register the action like so (rough code):
AIActionParamTypeRef actionParameters = 0;
AIErr error = sAIActionManager->AINewActionParamType(&actionParameters);
// add parameters using AIActionSetType
// register action with RegisterActionEvent & actionParameters
// clean up when done
sAIActionManager->AIDeleteActionParamType(actionParameters);
Next, when you are about to execute the functionality you described when you registered the action, you check to see if the user is recording:
if (sAIActionManager->InRecordMode()) {
AIActionParamValueRef valueBlock;
AIErr error = sAIActionManager->AINewActionParamValue(&valueBlock);
// e.g.
sAIActionManager->AIActionSetReal(valueBlock, 'valu', 10.0f);
sAIActionManager->RecordActionEvent("my_action_name", kDialogOff, valueBlock);
// clean up
sAIActionManager->AIDeleteActionParamValue(valueBlock);
Now the action has been recorded. It should show up in the Action panel.
Lastly, when the user plays the action, you'll get a call/selector of kActionCaller / kDoActionSelector (see AIActionManager.h). When you get that, you need to cast the message void* to a DoActionMessage. It has a AIActionParamValueRef member param, from which you pull out the action values:
DoActionMessage* doActionMessage = reinterpret_cast<DoActionMessage*>(message);
AIReal value = 0.0f;
AIErr error = sAIActionManager->AIActionGetReal(message->param, id, &value);
// pull out other parameters if there are any
// do your functionality!
There are a bunch of other parameters with registering & recording actions you should play with. You can record enums, for example, which let you store a value like '10' with a string to describe it. You can also specify whether or not your functionality has a dialog or not, and let the action indicate if they want to show your dialog or not (they want to stop and tweak action parameters halfway through a playback).
Hope that helps!
Thank you, A. Patterson! I have a problem not finished: I created a plugin named "Rename Art" showed on the Tool panel. when I click on it will rename all arts selected. this plugin has executed exactly. could I call it in vb.net script? if could, how do I have to do ? Thank you so much
Not quite sure I'm understanding you, but I think you're asking if you can invoke a plugin from ExtendScript (or just scripting in general)?
The answer is...sort of. AIScriptMessage.h has the C++ end of things, but I'm struggling to remember how you invoke that from script.
I think it's like so:
app.sendScriptMessage("exact_plugin_name", "function_name", "parameter1, parameter2, parameter3");
If you look at AIScriptMessage.h, it has sample code for catching the related caller and pulling out the information. It's pretty crappy, but it should work.
I mean: I created a plugin do anything (ex: rename all arts,...). After, I create a Tool using VB.net, this Tool will rename all objects in a file illustrator. In my Tool, can I use the plugin created before ? if can, how do i have to do ? Thank you so much!
I'm afraid I don't have any experience VB.net so I don't know what's possible there. Maybe someone else will have some experience that can shed some light on it. Good luck though!
