Custom Ruling & Shading via ExtendScript
Dec 21, 2016 Dec 21, 2016
I've taken up learning ExtendScript to tackle some common problems in my workflow.
My current project is to write a scrip that applies white rules to the columns in table heading rows.
So far my script can select the top (heading) row of the appropriate tables. But I can't figure out what the commands are for applying ruling. I've searched through every piece of documentation I could get my hands on, but there doesn't seem to be extensive material written with the beginner in mind.
Here's the script so far (Note: the counter and the alerts are just there so I know everything is working as I go along):
//target the active document
var doc = app.ActiveDoc;
//target the "first" table
var table = doc.FirstTblInDoc;
//number of tables to edit
var numberOfTables = 0;
if(table.ObjectValid() == true)
    while(table.ObjectValid() == true)
        if(table.TblTag == "WithHeading")
            numberOfTables++;
            alert("The table '" + table.TblTag.toString() + "' will be edited.");
            //select the top row of the table
            table.MakeTblSelection(0, 0, 0, table.TblNumRows - 1);
            table = table.NextTblInDoc;
        else
            alert("The table '" + table.TblTag.toString() + "' will not be edited.");
else
    alert("No more tables.");
alert(numberOfTables + " tables will be edited.");
Scripting
533
Community Expert , Dec 22, 2016 Dec 22, 2016
Once I get my code working on a single table, then I expand it to work on the entire document. Notice my liberal use of functions to keep things modular. Modular code is easier to test, troubleshoot and reuse. Please let me know if you have any questions or comments.
#target framemaker
main ();
function main () {
    if (doc.ObjectValid () === 1) {
        processDoc (doc);
    else {
        alert ("There is no active document.");
function processDoc (doc)
I am a little pressed for time but I am going to try to answer this today. First of all, one of the fundamentals: you want to get your code working on a single table before looping through all of the tables in the document. So we will start with this (make sure your cursor is in a single table):
#target framemaker
// The table containing your text cursor.
var tbl = doc.SelectedTbl;
// The first row of the table.
var row = tbl.FirstRowInTbl;
// The first cell in the row.
var cell = row.FirstCellInRow;
// Loop through the cells.
while (cell.ObjectValid () === 1) {
    // We will do something here.
    cell = cell.NextCellInRow;
The code that you need to apply the white rules will go at line 15. Note that when you use scripting, there is no need to select the row, you just need to loop through the cells. I will try to post the rest of the code shortly.
-Rick
Here is working code with some comments:
#target framemaker
// The ruling format to apply to the row's columns.
var rulingFmt = getRulingFmt ("1ptWhite", doc);
    // Process all of the cells in the row, except the last cell.
    if (cell.NextCellInRow.ObjectValid () === 1) {
        // Apply the ruling format to the right side of the cell.
        cell.CellOverrideRightRuling = rulingFmt;
        cell.CellUseOverrideRRuling = 1;
// Refresh the document display.
doc.Redisplay ();
function getRulingFmt (name, doc) {
    var rulingFmt;
    // Get the ruling format.
    rulingFmt = doc.GetNamedRulingFmt (name);
    if (rulingFmt.ObjectValid () === 0) {
        // If it doesn't exist, create it.
        rulingFmt = doc.NewNamedRulingFmt (name);
        rulingFmt.Pen = Constants.FV_FILL_WHITE;
        rulingFmt.RulingPenWidth = 1 * 65536; // 65536 = 1 point
        rulingFmt.RulingLines = 1;
    return rulingFmt;
#target framemaker
main ();
function main () {
        processDoc (doc);
    else {
function processDoc (doc) {
    var tbl, rulingFmt;
    // Get the required ruling format.
    // Process all of the tables in the document.
    tbl = doc.FirstTblInDoc;
    while (tbl.ObjectValid () === 1) {
        // Test for the correct table format.
        if (tbl.TblTag === "WithHeading") {
            processTbl (tbl, rulingFmt);
        tbl = tbl.NextTblInDoc;
    doc.Redisplay ();
function processTbl (tbl, rulingFmt) {
    var row, cell;
    // Get the first row of the table and the first cell in the row.
    var rulingFmt;
    return rulingFmt;
Dec 23, 2016 Dec 23, 2016
First of all, I'd like to thank you for the unexpectedly-detailed reply : )
I'll spend some time processing this and am sure I'll have some questions.
But for now, happy holidays!
