Hi All
I need to resize the polycon box based on the text frame height. How to do this with indesign script
Here I have copied the screen short
Given that you select the polygon and the rectangle you could use.
So you just need to adapt this to your preferred method of identifying the polygon and rectangle.
Using select is really bad practice.
HTH
Trevor
...// By Trevor www.creative-scripts.com
var padding, paddingFromCurve, paddingRefencePoint, shapes, path, polygonEntirePath, l, c, pointMap, p, rectangleLow, polygonAdjustment;
if (!app.properties.activeDocument) exit();
padding = toDocUnit('3mm'); // change as needed
paddingFromCurve = true; // c
Well you need to read at the visibleBounds property of the textframe (which you can access through the applied XML Element), then relocate the bottom points of the polygon accordingly. Question here would be to access this polygon easily (is this part of a group with the text frame ?)
I am using this method to find the polycon inside the group
var myDoc = app.activeDocument;
var myGroups= myDoc.groups
var pItems = myGroups[0].pageItems;
for (var j =0; j<pItems.length; j++)
var curItem = pItems
var constrName = curItem.constructor.name;
if (constrName == "Polygon")
app.toolBoxTools.currentTool = UITools.DIRECT_SELECTION_TOOL; // to select the Polygon
app.select(curItem)
if you can presume the polygon is a direct child of the group then no need for looping
myGroups[0].polygons[0] //assuming it's the first polygon of the group you are interested in…
etc.
Hi together,
note, that there is one speciality with this situation.
Do not do this:
1. Change size by changing the geometricBounds
2. Change size by scaling
Instead move some of the pathpoints of the polygon:
It could also be that the polygon is constructed with more than 6 path points.
Or even more…
And then you are a bit into trouble. 😉
Uwe
// EDITED
How can I do this please advice. I am very little bit knowledge in scripting
HTH
Trevor
paddingFromCurve = true; // change as needed
function toDocUnit(n) {
return UnitValue(n).as(app.scriptPreferences.measurementUnit === AutoEnum.AUTO_VALUE ? app.activeDocument.viewPreferences.verticalMeasurementUnits : app.scriptPreferences.measurementUnit) || +n || 0;
function getShapes() {
var thePolygon, theRectangle, selection;
// Check you've selected the 2 shapes
selection = app.selection;
if (!selection ||
selection.length !== 2 ||
!('paths' in selection[0]) ||
!('paths' in selection[1]) ||
selection[0].paths.length !== 1 ||
selection[1].paths.length !== 1
alert('You need to select the rectangle and the polygon.');
exit();
// Identify which of the selected items is the frame //
// This test could fail in a bunch of cases but it most likely won't //
// So unless we hear differently //
if (selection[0].paths[0].pathPoints.length === 4) {
theRectangle = selection[0];
} else if (selection[1].paths[0].pathPoints.length === 4) {
theRectangle = selection[1];
// Identify which of the selected items is the polygon //
if (selection[0].paths[0].pathPoints.length > 4) {
thePolygon = selection[0];
} else if (selection[1].paths[0].pathPoints.length > 4) {
thePolygon = selection[1];
// All going well we should have identified the frame and the polygon //
// But we'll check to be sure //
if (!theRectangle || !thePolygon) {
exit();
return {
rectangle: theRectangle,
polygon: thePolygon
shapes = getShapes();
// find the bottom four points of the polygon //
// Again we're use the simplest method //
// it will work in most cases let us know if it doesn't //
path = shapes.polygon.paths[0];
polygonEntirePath = path.entirePath;
l = polygonEntirePath.length;
pointMap = [];
for (c = 0; c < l; c++) {
pointMap.push([c, polygonEntirePath
[2] ? polygonEntirePath [1][1] : polygonEntirePath [1]]); // the index and the vertical anchor point }
// sort the points //
pointMap.sort(function(a, b) {
return b[1] > a[1];
// Get the lowest 4 points of the polygon
pointMap = pointMap.splice(0, 4);
// get low point of rectangle //
rectangleLow = shapes.rectangle.geometricBounds[2];
paddingRefencePoint = paddingFromCurve ? 3 : 0;
polygonAdjustment = rectangleLow - (pointMap[paddingRefencePoint][2] ? pointMap[paddingRefencePoint][1][1] : pointMap[paddingRefencePoint][1]) + padding;
l = pointMap.length;
while (l--) {
p = pointMap
[0]; if (polygonEntirePath
[2]) {
polygonEntirePath
[0][1] += polygonAdjustment;
polygonEntirePath
[1][1] += polygonAdjustment;
polygonEntirePath
[2][1] += polygonAdjustment;
} else {
polygonEntirePath
shapes.polygon.paths[0].entirePath = polygonEntirePath;
Now given your screenshot and that you are working with a group.
Then you could try the beneath.
This presumes your group are of a fixed structure.
You need to change the indexes in line 14 to make sure you get correct item being adjusted according to the correct item.
shapes = {rectangle: myGroup.pageItems[3], polygon: myGroup.pageItems[0]};
If you were to apply this to a several groups you would want to cache the polygons low point indexes.
Before:
After
// jshint undef: true, unused: true
var myGroup, doc;
doc = app.properties.activeDocument;
if (!doc) exit();
myGroup = doc.groups[0];
return UnitValue(n).as(app.scriptPreferences.measurementUnit === AutoEnum.AUTO_VALUE ? doc.viewPreferences.verticalMeasurementUnits : app.scriptPreferences.measurementUnit) || +n || 0;
pointMap = [];
return b[1] > a[1];
while (l--) {
p = pointMap
[2]) {
polygonEntirePath
polygonEntirePath
polygonEntirePath
} else {
polygonEntirePath
Edit: Jive's is playing up, hence the lack of formatting
before doing anything you have to analyze the polygon you want to change.
Some important questions:
1. Are rounded corners applied with InDesign's corner options?
2. How many path points are at the very bottom of the polygon?
( Select the polygon with the Direct Selection Tool and count.)
If 1 is true, there is a good chance, that only 2 path points should be moved.
If not, you have to adapt pointMap.splice() in Trevor's snippet.
Some other questions:
How many groups like the one in your screenshot are in your document?
Is every polygon you want to change constructed the same way?
( Number of path points, corner options applied or not. )
What should be the distance from the baseline of the last line of text to the bottom edge of the polygon?
( I guess this is what we are after and not the distance of the bottom edge of the text frame to the bottom edge of the polygon.)
Uwe
Thanks you so much trevor. Its working for me. I have only one polygon inside the group.
But i am reading each and every lines in your script. If i have any doubts i will ask you.
I very glad to part of this forum.
Hi Keyank
With all due respect to Loic in #1 above who is an excellent professional scripter, I think my answer at #6 or #7 should be marked as correct.
So please with Loic's approval unmark his answer as correct and mark mine as correct.
It's done.
