Is it possible to check in the background if the user has selected a gradient mesh without prompting the user to select a gradient mesh and only prompt the user to
select a gradient mesh once ? I can't find in the reference guide how to select the direct selection tool ?
var GrdntMesh = mDoc.meshItems.selection = 0;
if (GrdntMesh == 0); {
prompt("Choose a Gradient Mesh Shape");
} else {};
test 'what is selected'
(function selectionCases() {
if ( _isTextMode () && _isNoSel () ) {
alert ( 'mode editing text, nothing is selected' );
} else if ( _isTextMode () && !_isNoSel () ) {
alert ( 'mode editing text, something is selected' );
} else if ( !_isTextMode () && _isNoSel () ) {
alert ( 'mode editing objects, nothing is selected' );
} else if ( !_isTextMode () && !_isNoSel () ) {
alert ( 'mode editing objects, something selected' );
alert (selection[0]);
function _isTextMode () { // mode editing text
return typeof selection.contents == 'string';
function _isNoSel () { // nothing is selected
return selection.length === 0;
What is _isTextMode ?
when
selection.typename == 'TextRange'; // true
StrongBeaver , you want to catch the event, at the time when the user has selected something by a Selection Tool?
New
Or run a script that checks which object is selected at the time of launch?
Using Illustrator ExtendScript perhaps only the second variant.
o-marat, Are isTextMode & _isNoSel variables ?
In JavaScript 'function is a value'.
This functions return values of type Boolean (all function that name begins to 'is' must returns boolean value);
Function is not a variable, it's a Object of class Function, but when function completed it becomes the returned value. In this case boolean true or false.
Like that...
Ah you're calling the functions isTextMode function within the selectionCases function
How can you verify if a meshItem is selected since it doesn't have a property or method ?
Maybe I misunderstood something...
for example:
if (selection[0].typename == 'MeshItem') // true or false
Is not that what you want?
If rewrite the function in your first post:
try {
duplicateAndMoveMesh(selection[0]);
} catch (e) {
alert(e); // something errors case
function duplicateAndMoveMesh(sel) {
var msg = 'Select Gradient Mesh object and run script again';
if (!_isTextMode() && !_isNoSel()) {
if (sel.typename == 'MeshItem') { // mode editing objects, something selected
// do something with mesh
var dpl = sel.duplicate();
dpl.translate(sel.width + 10, 0, true, true, true, true);
} else if (_isTextMode() && !_isNoSel()) { // mode editing text, something is selected
alert(msg);
} else if (!_isTextMode() && _isNoSel()) { // mode editing objects, nothing is selected
alert(msg);
} else if (_isTextMode() && _isNoSel()) { // mode editing text, nothing is selected
alert(msg);
function _isTextMode() { // mode editing text
function _isNoSel() { // nothing is selected
Gradient Mesh has a method for selected but can you not assign a Boolean and leave it empty and let a condition or try clause let that be the decision maker whether it's true or false ?
I think now I'm not understand what is needed and what targets... %\
Perhaps will answer the one who understood.
I need more detailed and simple description of your workflow.
I can't use the following code;
var GrdntMesh = mDoc.meshItems.selected;
because the method selected requires a Boolean property. I was wondering if I could leave the above line but let the Boolean property of selected be decided based on a condition / try clause ? If I'm approaching this wrong, sorry
it's this?
var GrdntMesh = mDoc.meshItems[0];
GrdntMesh.selected = true;
Hrm, Sill that may have worked, and I say may as I don't know whether I can nest a condition into a try clause, I keep getting an error ?
try {
if (GrdntMesh.selected = 1) {
alert("Gradient Mesh is selected");
} else {
catch{
(GrdntMesh.selected = 0); {
alert("Please Select a Gradient Mesh");
Wrong syntax
var GrdntMesh = app.activeDocument.meshItems[0];
//try {
if (GrdntMesh.selected == true) {
} else {
//catch{
if (GrdntMesh.selected == false); {
