This camera does not have a lens profile. I have read that Lightroom automatically corrects for this Camera, but I don't think it does (When I try another Fujifilm profile, it looks less distorted). What profile would you suggest would accommodate my camera best. My actual lens is a Fujifilm XF 18-55 zoom. Thanks.
[Moved from non-technical Forum Lounge to Lightroom forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
There is no lens profile for this camera. The lens corrections have already been applied.
See Work with lens profiles in Adobe Photoshop, Lightroom, and Camera Raw
The X-T10 is an interchangeable lens camera. To my knowledge (I own a X-E2) it uses the same exact sensor as the X-E2 and X-T1.
It also uses the same exact lenses as all other X series cameras and all the profiles for all the Fuji lenses are built into LR.
I own the 18-55mm lens and LR makes the correct adjustments for it.
What you don't want to do is place a check mark in the "Enable Profile Corrections" check box. With this option unchecked this is what you get when clicking on the "i" icon near the bottom of the Lens Correction section of the Develop module.
So no manual correction or selection of lens profile is needed.
If you are shooting JPG images then the corrections are applied "In Camera" to the RAW Data coming from the sensor before it is saved as a JPG to the memory card.
