In the latest LR release, I can not remove curve points by dragging off the graph? Am I doing something wrong?
It's a requested change that was implemented in LR 6.8 and CC 2015.8: Lightroom 6.8: Can no longer delete curve points by dragging them off the sides | Photoshop Family Customer Community
You can now also delete control points by double-clicking on them,but the ability to move control points with the arrow keys has been removed.
Greater Accuracy with the Tone Curve « Julieanne Kost's Blog
Apparently the change was made to fix a bug introduced in LR 6.7 and CC 2015.7. So they fixed the bug and too
...Copy link to clipboard
Right-click and select 'Delete Control Point.' I think in previous LR versions you could drag them off-screen...not sure.
In Windows-10 CC2015.8
Same as the OP seen here- Control points cannot be dragged off the curve line.
As per trshaner- a right-click and 'delete' individual points, or 'flatten curve' deletes ALL!
I'm aware of the right click function... thought I was losing my mind. The drag off is super fast.
Doesn't work on the Mac either.
It's a requested change that was implemented in LR 6.8 and CC 2015.8: Lightroom 6.8: Can no longer delete curve points by dragging them off the sides | Photoshop Family C...
Apparently the change was made to fix a bug introduced in LR 6.7 and CC 2015.7. So they fixed the bug and took away drag-delete and arrow key control of the control points.
This is the way Adobe has fixed a couple other bugs in the past, just remove the capability Actually, for this fix I prefer the double-click remove instead of the the drag-remove method. Is the double-click NEW or was I just not aware of the old behavior? Thanks for the info on the double-click anyway.
