I don't reading to jsxbin file. Please help me.
The best way is to ask the author of the script to send you an unencoded version.
If someone has encoded their files, it's probably because they don't want you to be able to read or edit them.
So impossible?
If someone answers "yes it's possible" and proceeds to tell you how, then you are going against the implicit request of the person who wrote that script to honor the agreement between him and you to not attempt and get the source. That request is implicitly there because its author chose to obfuscate the script. If he did not mind having others see the source, he would not have done that.
So as a script writer myself, I'm going to repeat TAW's answer: no.
So impossible?
Not at all! It's usually possible, with a bit of effort, to get hold of the author's email and send them a polite request.
I write a script. So i use jsxbin because nobody read?
That's correct. You use jsxbin so nobody should read.
It's a lock on the scripts contents, not the best but a lock.
This is an articular on the topic HTML Panel Tips #22: Protecting your Code | Photoshop, etc.
Thanks for help 🙂
