Hi everyone,
I am using Lightroom for a while with latest update on my laptop running Windows 7 and never had any issue with importing and working on Nikon D500 .NEF files.
I have now a new PC with Windows 10 and can not import D500 .NEF file anymore in Lightroom (no problem with other cameras Nex6 & D7100)
All the updates of Lightroom & Camera Raw are done. I can open without any trouble those D500 .NEF files within photoshop or other Adobe Sofwtare but not with Lighroom 2015.
Converting to DNG is not a very efficient solution according to me even if it's the only solution for me so far.
Would anyone have any idea to solve this issue?
Thank you in advance.
Kind regards,
Sylvain
Hi everyone,
Just to let you know that I finally solved it.
After a lot of different advices tested, the solution mentionned here by kglad was the one which helped : Updating up to Photoshop 2017 under Windows 10
I launched all the installations in last step as Admin (right click)
However I had an issue with U44M1P7 but at least now I can update by downloading the AdobePatchInstaller which was not possible previously 🙂
thanks a lot to all for your precious support.
Have a great day
Please post the exact version of LR you are using. Help > About Adobe PS LR. At the top left the version is listed.
Also Help > System Info.
We need to know the version NUMBER of your Lightroom. Please go to Help->System Info and report the version NUMBER of your Lightroom shown there.
We need to know, in detail, what happens when you try to do the import. Explain. If there is an error message, please quote the exact complete unedited word-for-word error message.
thanks for your response.
Here it is :
Lightroom version : CC 2015 [1014445]
Licence: Creative Cloud
Camera RAW 9.0
When I try to import a D500 .NEF file, I get the following message (translation from FR):
Original message in French:
"Le fichier n'est pas reconnu par la prise en charge du format Raw de Lightroom (1)"
Message translated in English:
"The file is not recognized by the Raw format support of Lightroom (1)"
thanks for your support, really appreciate.
You have to update (free) to Lightroom CC 2015.8
I've tried a couple of things to check it was the last update but it was always seen as the latest version. I'll try to reinstall the software and keep you updated.
What OS are you using? If it is Windows is it a 64 bit version or a 32 bit version?
I am using a x64 version of Windows 10
Pending, I've tried to uninstall and reinstall but still same issue, don't get possibility to update to 2015.8
I have now tried to download from the page your shared with me and install this version but I can not install this "AdobePatchInstaller"
"If you want to apply updates to your machine, contact your administrator because he deleted those updates"
This message doesn't make any sense to me, plus I am the admin.
Do you have any idea?
Thanks a lot 🙂
Then this is a permissions problem or it could be do to whatever internet security program you are running.
Try downloading a slightly older update version like 2015.6.1 and see if that will install. If it does then try the .8 update again.
same problem with 2015.6.1.
very strange
Did you by any chance uninstall LR before doing the update? That would be the wrong thing to do. Let us know.
I first uninstalled LR via the Adobe Creative tool and reinstalled it, and yes indeed try to install the update after via the Adobe Patch.
Uninstalling LR is not the right thing to do.
The steps you need to follow now are:
Thank you very much for your support
I followed your instructions but unfortunatelly I still can not install the 2015.8 patch.
What I really don't understand is :
- why can I click on "Check for update..." in any Adobe software on my laptop but not on my other PC? (UAC is turned off)
- why Adobe Creative Cloud tool detect required updates on my laptop but not on my other PC? (UAC is turned off)
- why Photoshop can open .D500 NEF files when Lightroom can not?
Why not? What happened?
They are different programs that have different requirements and different underlying code and work differently.
I still face the same issue when launching the AdobePatchInstaller
So, have you properly performed step 1 above which says "Download and install the Application Installer from Install Photoshop Lightroom"? If you did this, you should have Lightroom CC 2015 installed and working properly. Is that where you are now?
Yes, I did. I now have Lightroom CC 2015 properly installed and running but no way to install updates.
I'm going to recommend that you post this issue in the Downloading, Installing and Setting Up forum.
thanks for your help, I will do 🙂
Hi everyone,
Have a great day
