I need to validate my adobe indesign preset before export PDF and enable the bookmark and hyperlink option. How to do this?
or..
var myPDFexportPreset = app.pdfExportPresets.item('Adobe PDF Preset 1');
myPDFexportPreset.includeBookmarks = true;
myPDFexportPreset.includeHyperlinks = true;
var myPDFname = app.activeDocument.name.split(".indd").join(".pdf")
var myPDF = new File("~/Documents/" + myPDFname);
app.activeDocument.exportFile(ExportFormat.pdfType, myPDF, false,myPDFexportPreset);
Check this..
Thanks tpk. But my question is after import the preset i need to enable the bookmark and hyperlink features. Is this possible
app.importFile(ExportPresetFormat.pdfExportPresetsFormat, myFile); | ||
var myPDFexportPreset = app.pdfExportPresets.item(myJoboptionsName); |
app.pdfExportPreferences.includeBookmarks = true;
app.pdfExportPreferences.includeHyperlinks = true;
just add this lines to enable bookmark and hyperlinks, is this you needed?
If you want this for preset use
app.pdfExportPreset.includeBookmarks = true;
app.pdfExportPreset.includeHyperlinks = true;
the below links also useful
Its working for bleed marks and its not working for bookmark
Could you post the entire coding of yours? So we can see where we are..
You used pdfExportPreferences instead of pdfExportPreset
also make sure you have Adobe PDF Preset 1 preset available
try this and let me know
or..
