Hi, I'm really new using After Effects, I'm currently working with a template, and I would like to move the composition from where it was originally created, how can I do this without affecting the entire animation?
I know is asking too much but if any of you guys could give me an step by step with visual aid I would greatly appreciated.
It didn't work 100%...can you help me?
you will need to be specific. what did you do? how did it not work? there's only so much one can figure out from a screenshot of a setup he never seen before
I see you have more than one layer you want to move and you choose option 2. did you move the layers? you are supposed to move the null.
click UU on all the layers so we can see everything and try to explain better
this question can be a few things. what exactly do you want to move? keyframes? entire layer? how exactly? show us so we can better assist you.
Sure, this what I'm working with
The composition is in the middle, and I need it to be place lower, how can I do that without affecting the keyframes.
1. select all the keyframes so they are highlighted
2. make sure your CTI is on one of them
3. move the layer in the composition window or scrub the values
this way you are offsetting the keyframes
OR
1. create a null: layer->new->null
2. connect the composition/layer to the null
3. move the null
4. delete the null
Sorry, it did work, thanks for your help
Good job. please mark the answer as correct so that others will find it quick, get a notice on a helpful response and so that yours truly will get closer to the hall of fame
