I have just bought the Samyang 8mm f3.5 cs2 fisheye lens and tried to download the lens profile for my Lightroom v5.7 but cannot although I read it is available. Can I presume correctly that I cannot install this profile to my version of Lightroom? If not is there any other way of obtaining this lens profile?
All the supported Samyang lenses require LR CC 2015 / LR 6: Supported lenses
Lens profiles are specific to the file format, and there are more profiles for raw images than for JPEG images. Could this apply in your case?
Thanks. As I thought. Fortunately the lens, as I see it, has very few issues. I am using raw images and I was only interested in automatically removing any slight chromatic aberration.
Now discovered it is so easy to correct this manually in Lightroom 5. Go to Develop + Color and tick “Remove Chromatic Aberration”. This removed slight fringing that I had at the edges and once done synced with all other images in the folder.
The sliders are also available if you wish to edit further.
