In de ontwikkelmodule ziet de foto er bij voor en na (y) er in na anders uit. Ik kan niet vinden wat daar de oorzaak van is. Graag een oplossing.
Hi bremstruik,
Open the "History" panel and check to see what adjustments have been made.
Does that help?
Mike
This is not the solution for the problem, because there are no adustments in history. The difference is there already after importing the foto.
And why Bezemstruik?
Sometimes settings are applied on import. What happens when you reset the develop settings on the photo? Does the appearance change? Can you show a screen shot of your interfaceshowing the before and after, with History showing?
I see your forum ID name as bremstruik, my apologies if that's not correct.
Mike
I have made a printscreen. You can see there is a difference in colour. Much more!
In history there is after importing: from metagegevens (dutch).
Is that why there is a difference? And what can I do?
Greetings, Bremstruik (It is okay)
Is there a solution for this problem?
Thanks, Bremstruik
