i am trying to put two images on the same file but cant work
out how to do it on Robo Screen Capture. I can do it on photoshop
with its layering tool but i dont see any capability on RH.
Anyone??
What I meant was open the image that you would be the the
lower layer in something like PhotoShop. So just get the first
image into RSC. Then paste the smaller image onto that. You will
only be able to save as one layer but it will give you the image
you want.
thats where i am struggling. i can copy one image from one
screen capture but pasting is a problem. When i attempt to do this,
some of the pasted image is hidden behind the canvass. somehow i
need to expand the canvass to accomodate both images but i dont
know how to do that?
You could achieve this with a bit of lateral thinking.
Capture your first image and insert it into a word file. Now
capture the image in the word file together with some space around
it. Then paste your second image where you want and save. Open the
image in something other than RSC and capture it getting rid of any
of the unwanted space.
If this all seems like too much trouble, perhaps you should
think about using a tool specifically designed for this purpose.
Just a thought.
You cannot enlarge the canvas so if one image is offset you
could do as Colum suggests.
Or in RSC grab an image of some white background, part of a
blank Word document or something, then paste both your images on
top in the required order.
