I have a .fla file names test.fla and I have this variable in it:
var my_var;
stage.addEventListener(MouseEvent.CLICK, onLoaded);
function onLoaded(e:Event):void
my_var = "myVariable";
//trace(my_var);
I have a .as file called Main.as.
I want to pass **my_var** from test.fla to the Main.as.
I will really appreciate, if you can help me in this matter!
It is noticeable that I have used the method mentioned in "http://stackoverflow.com/questions/9603049/actionscript-3-pass-a-variable-from-the-main-fla-to-exter...", but it does not work for me!!!
I wrote in my Main.as:
package
public class Main extends Sprite
public function Main()
trace(root.my_var);
Thanks in advance!
make Main your document class and have it extend the MovieClip class.
kglad it is here!
Plz help me!
kglad Main is already document class and I extend to MovieClip class.
the code is like this:
test.fls:
import Main;
var my_var;
my_var = "Maziar";
//trace(my_var);
Main.as
package
import flash.display.Sprite;
import flash.geom.Point;
import flash.events.MouseEvent;
import flash.utils.Timer;
import flash.events.TimerEvent;
import flash.events.Event;
import flash.display.MovieClip;
public class Main extends MovieCLip
if (stage)
init();
else
addEventListener(Event.ADDED_TO_STAGE, init);
addEventListener(Event.ENTER_FRAME, waitForMyVar);
private function waitForMyVar(e:Event):void
if (my_var != null)
trace(my_var);
removeEventListener(Event.ENTER_FRAME, waitForMyVar);
private function init(e:Event = null):void
removeEventListener(Event.ADDED_TO_STAGE, init);
I still get the errors "error: 1120: Access of undefined property my_var".
the error is in line: if (my_var != null) and line : trace(my_var);
that couldn't have been your document class or you would have seen an error.
anyway, use:
test.fls:
import Main;
var my_var;
my_var = "Maziar";
dispatchEvent(new Event('varReadyE'));
Main.as
package
if (stage)
init();
else
this.addEventListener('varReadyE',waitForMyVar);}
trace(my_var);
Thanks again!
But I have still this error:
1120: Access of undefined property my_var. |
In line:
trace(my_var);
In Main.as
I have changed trace(my_var) to trace ("Hello") and it does not work also.
attach a screenshot of your properties panel that shows Main is your document class:
