Once I return to Lightroom from editing in ON1 I see a 1 of 2 next to my photo however I cannot find the second (#2) photo I click on. It will not show my edited photo. This is driving me crazy...I hit YY button and can see the second photo but it won't let me click on it to export that one...
Thanks in advance
L
1 of 2 also denotes a Stacked image. The stacked images should be right next to one another. Make sure the Sort: is set to Capture Time.
Normally when Lr sends a file to an external editor (then 'Save' from the editor) the file comes back to Lr as a separate new file. It would not show "1 of 2" anywhere.
"1 of 2" indicates you are looking at a Virtual copy of the original, not the file from ON1.
It is possible your folder Sort Order is set to 'Capture Time' and the new ON1 file is being placed at the very bottom of the images in the folder. Does setting the Sort Order to "Filename" have any result?
The YY button may be selecting the Original and the Virtual copy visible next to it (not the ON1 file)
I cannot find "Sort Order" can you tell me where to find it? thanks for the help
I just hit split stack and now see both images
The Sort: is in the Tool Bar. Hit the t key if you don't see it near the bottom of the LR Library module.
You are awesome thank you so much...really appreciate your time and patience.
Lorraine
