I mark files to be deleted with an X, then do CMD+Del. The files delete but the photo that is on the screen (loupe) will not change. If I try to change to Library or any other Module, I get a message - LR encountered an error when changing modules. I have to shut LR down and restart it to go back to work. Not fun!
Yes it is a bug in the new version and will be addressed in the next update. For now if you don't want the problem you are having switch to the Library module before deleting images.
Before you Delete images switch back to the Library module.
Why should I have to? This error was not there in earlier versions of LR. I think it should be reported as a bug.
Thank you!
Thank you! Exactly the same problem being experienced here.
