When I pause my animation the audio stops and I have to restart the entire thing. Help?
i don't think you can do much about that. the sound will continue to play when testing even when the timeline stops. be careful to not reenter the frame where the sound starts while the sound is still playing. actually, it's not a great idea to use sound attached to a timeline unless you need to sync the sound to animation.
if you're attaching your sound to a frame, use event (not stream) if you want the sound to continue to play once it starts.
otherwise, canvas or actionscript?
It's on event, but when I pause it, I have to set it at the beginning of they keyframe to get it to play again.
your sound stops when you execute a stop() on your timeline?
if so, attach a screenshot of your frame 1's properties panel that shows your sound is attached and its sync property is 'event'.
that looks correct.
now are you stopping your timeline in the ide or when testing (by using a stop(), eg)?
Yeh, I press the pause button to add something and when I unpause it to see if it's correct it stops.
