A fairly common problem for us is having a large file, say ~100 pages, where we have to duplicate each page X number times, so that each duped page is added after the original.
For example: I have to duplicate each page of a 100 page file 5x so that in the end I have a file with pages in this order: 1, 1, 1, 1, 1, 2, 2, 2, 2, 2, 3...
Normally when you duplicate 100 pages, it puts the pages at the end of the file. And while I know you can OPT-Drag pages to duplicate them where you want (in fact, I have a script with a shortcut to do this), many of our jobs are very large and it's not feasible to dupe 100 pages 5x each... 1 at a time. It's both too time consuming and introduces a large chance you'll make a mistake along the way.
Is there a script out there where you can quickly duplicate a large file in the order above? Or perhaps some trick to achieve the same result?
You can try this snippet ...
var doc = app.documents[0];
var nbPage = doc.pages.length; // count doc pages
var n = 5; // duplicate number
for (i = 0; i < nbPage; i++) {
var sourcePage = doc.pages.item(i + (i*n));
for (j = 0; j < n; j++) {
sourcePage.duplicate(LocationOptions.AFTER, doc.pages.item(i + (i*n)));
That's great - thank you!
While that is completely usable as is, is there any way to add a little popup so you can enter the number of duplicates you wanted?
Thanks again!
Like this ?
var n = prompt('Enter a number between 1 and 99.', '', 'Name of dialog');
var reg = /^\d{2}$/;
if (reg.test(n)){
}else{
alert('Error \r Must be a number between 1 to 99');
Oups my regex was wrong ...
var reg = /^\d{1,2}$/;
if (reg.test(n)){
}else{
That is *exactly* what I needed - THANK YOU!
you've just saved me a lot of time, thank you so much
I'm new to scripts, so here is my question. I have a large document of 1000 pages, each of them needing a different number of copies per page (from 2 - 6 copies ) do i create this script 5 times ?
Script 1 make 2 copies of this page... script 2 make 3 copies of this page... script 3 make 4 copies of this page?
This is way better than dragging with the Ctrl function.
Here is the task I have to do
Page | copies |
388 | 4 |
389 | 4 |
390 | 2 |
391 | 2 |
392 | 1 |
393 | 3 |
394 | 2 |
395 | 3 |
396 | 2 |
397 | 1 |
398 | 5 |
399 | 1 |
400 | 1 |
401 | 4 |
402 | 3 |
403 | 2 |
404 | 3 |
405 | 3 |
406 | 4 |
407 | 6 |
408 | 4 |
409 | 2 |
410 | 2 |
411 | 6 |
412 | 3 |
413 | 3 |
414 | 4 |
415 | 4 |
416 | 6 |
417 | 4 |
418 | 1 |
419 | 2 |
420 | 2 |
421 | 5 |
422 | 6 |
423 | 4 |
424 | 3 |
425 | 2 |
426 | 5 |
427 | 2 |
428 | 4 |
429 | 2 |
430 | 1 |
431 | 3 |
432 | 2 |
433 | 4 |
434 | 6 |
435 | 4 |
436 | 2 |
437 | 2 |
438 | 2 |
439 | 4 |
440 | 3 |
441 | 3 |
442 | 5 |
443 | 3 |
444 | 3 |
445 | 3 |
446 | 2 |
447 | 1 |
448 | 5 |
449 | 3 |
450 | 2 |
451 | 2 |
452 | 2 |
453 | 2 |
454 | 1 |
455 | 3 |
456 | 2 |
457 | 3 |
458 | 4 |
459 | 3 |
460 | 2 |
461 | 2 |
462 | 1 |
463 | 5 |
464 | 4 |
465 | 4 |
466 | 3 |
467 | 3 |
468 | 3 |
469 | 1 |
470 | 3 |
471 | 2 |
472 | 2 |
473 | 2 |
474 | 4 |
475 | 3 |
476 | 1 |
477 | 1 |
478 | 2 |
479 | 3 |
480 | 4 |
481 | 2 |
482 | 1 |
483 | 2 |
484 | 4 |
485 | 2 |
486 | 5 |
487 | 3 |
488 | 2 |
489 | 3 |
490 | 4 |
491 | 3 |
492 | 3 |
493 | 2 |
494 | 3 |
495 | 3 |
496 | 4 |
497 | 2 |
498 | 5 |
499 | 6 |
500 | 2 |
501 | 3 |
502 | 1 |
503 | 1 |
504 | 1 |
505 | 4 |
506 | 3 |
507 | 4 |
508 | 5 |
509 | 1 |
510 | 3 |
511 | 4 |
512 | 5 |
513 | 3 |
514 | 3 |
515 | 3 |
516 | 5 |
517 | 2 |
518 | 1 |
519 | 2 |
520 | 3 |
521 | 2 |
522 | 3 |
523 | 5 |
524 | 5 |
525 | 5 |
526 | 1 |
527 | 3 |
528 | 3 |
529 | 3 |
530 | 4 |
531 | 3 |
532 | 3 |
533 | 4 |
534 | 5 |
535 | 3 |
536 | 4 |
537 | 2 |
538 | 6 |
539 | 4 |
540 | 3 |
541 | 3 |
542 | 3 |
543 | 2 |
544 | 2 |
545 | 4 |
546 | 3 |
547 | 3 |
548 | 2 |
549 | 2 |
550 | 4 |
551 | 2 |
552 | 4 |
553 | 6 |
554 | 2 |
555 | 2 |
556 | 1 |
557 | 4 |
558 | 5 |
559 | 6 |
560 | 4 |
561 | 2 |
562 | 5 |
563 | 4 |
564 | 2 |
565 | 4 |
566 | 1 |
567 | 6 |
568 | 5 |
569 | 4 |
570 | 5 |
571 | 6 |
572 | 1 |
573 | 3 |
574 | 3 |
575 | 2 |
576 | 3 |
577 | 2 |
578 | 2 |
579 | 1 |
580 | 4 |
581 | 3 |
582 | 2 |
583 | 3 |
584 | 6 |
585 | 4 |
586 | 1 |
587 | 3 |
588 | 4 |
589 | 1 |
590 | 4 |
591 | 1 |
592 | 5 |
593 | 3 |
594 | 4 |
595 | 2 |
596 | 2 |
597 | 6 |
598 | 3 |
599 | 4 |
600 | 2 |
601 | 3 |
602 | 5 |
603 | 4 |
604 | 4 |
605 | 3 |
606 | 1 |
607 | 3 |
608 | 1 |
609 | 3 |
610 | 6 |
611 | 6 |
612 | 3 |
613 | 2 |
614 | 2 |
615 | 5 |
616 | 6 |
617 | 3 |
618 | 3 |
619 | 5 |
620 | 2 |
621 | 2 |
622 | 4 |
623 | 2 |
624 | 1 |
625 | 5 |
626 | 2 |
627 | 4 |
628 | 3 |
629 | 3 |
630 | 4 |
631 | 2 |
632 | 4 |
633 | 2 |
634 | 2 |
635 | 3 |
636 | 3 |
637 | 1 |
638 | 3 |
639 | 5 |
640 | 2 |
641 | 4 |
642 | 2 |
643 | 1 |
644 | 3 |
645 | 3 |
646 | 3 |
647 | 3 |
648 | 3 |
649 | 5 |
650 | 2 |
651 | 4 |
652 | 6 |
653 | 4 |
654 | 1 |
655 | 5 |
656 | 2 |
657 | 5 |
658 | 1 |
659 | 3 |
660 | 5 |
661 | 3 |
662 | 2 |
663 | 3 |
664 | 5 |
665 | 2 |
666 | 3 |
667 | 2 |
668 | 4 |
669 | 3 |
670 | 3 |
671 | 2 |
672 | 2 |
673 | 5 |
674 | 3 |
675 | 4 |
676 | 1 |
677 | 4 |
678 | 6 |
679 | 1 |
680 | 1 |
681 | 4 |
682 | 6 |
683 | 4 |
684 | 1 |
685 | 4 |
686 | 3 |
687 | 4 |
688 | 2 |
689 | 2 |
690 | 2 |
691 | 5 |
692 | 1 |
693 | 2 |
694 | 1 |
695 | 6 |
696 | 1 |
697 | 4 |
698 | 3 |
699 | 3 |
700 | 4 |
701 | 2 |
702 | 2 |
703 | 3 |
704 | 5 |
705 | 3 |
706 | 2 |
707 | 3 |
708 | 2 |
709 | 3 |
710 | 3 |
711 | 4 |
712 | 3 |
713 | 2 |
714 | 3 |
715 | 3 |
716 | 3 |
717 | 5 |
718 | 3 |
719 | 3 |
720 | 5 |
721 | 3 |
722 | 1 |
723 | 3 |
724 | 5 |
725 | 4 |
726 | 2 |
727 | 3 |
728 | 1 |
729 | 6 |
730 | 2 |
731 | 3 |
732 | 3 |
733 | 2 |
734 | 6 |
735 | 2 |
736 | 4 |
737 | 3 |
738 | 2 |
739 | 3 |
740 | 3 |
741 | 3 |
742 | 1 |
743 | 4 |
744 | 4 |
745 | 3 |
746 | 6 |
747 | 2 |
748 | 3 |
749 | 3 |
750 | 5 |
751 | 4 |
752 | 3 |
753 | 3 |
754 | 5 |
755 | 3 |
756 | 1 |
757 | 4 |
758 | 2 |
759 | 5 |
760 | 2 |
761 | 4 |
762 | 2 |
763 | 2 |
764 | 2 |
765 | 2 |
766 | 3 |
767 | 2 |
768 | 3 |
769 | 3 |
770 | 2 |
771 | 5 |
772 | 2 |
773 | 2 |
774 | 4 |
775 | 3 |
776 | 5 |
777 | 3 |
778 | 4 |
779 | 5 |
780 | 3 |
781 | 1 |
782 | 3 |
783 | 2 |
784 | 3 |
785 | 2 |
786 | 4 |
787 | 2 |
788 | 3 |
789 | 2 |
790 | 2 |
791 | 3 |
792 | 1 |
793 | 2 |
794 | 3 |
795 | 4 |
796 | 5 |
797 | 2 |
798 | 2 |
799 | 6 |
800 | 3 |
801 | 2 |
802 | 3 |
803 | 3 |
804 | 6 |
805 | 4 |
806 | 4 |
807 | 5 |
808 | 2 |
809 | 4 |
810 | 4 |
811 | 2 |
812 | 3 |
813 | 2 |
814 | 3 |
815 | 6 |
816 | 2 |
817 | 2 |
818 | 6 |
819 | 4 |
820 | 1 |
821 | 5 |
822 | 3 |
823 | 3 |
824 | 5 |
825 | 6 |
826 | 4 |
827 | 3 |
828 | 3 |
829 | 6 |
830 | 4 |
831 | 2 |
832 | 4 |
833 | 2 |
834 | 3 |
835 | 1 |
836 | 3 |
837 | 3 |
838 | 3 |
839 | 3 |
840 | 4 |
841 | 2 |
842 | 4 |
843 | 4 |
844 | 4 |
845 | 4 |
846 | 1 |
847 | 1 |
848 | 5 |
849 | 2 |
850 | 2 |
851 | 3 |
852 | 1 |
853 | 3 |
854 | 2 |
855 | 1 |
856 | 4 |
857 | 4 |
858 | 3 |
859 | 6 |
860 | 3 |
861 | 6 |
862 | 4 |
863 | 3 |
864 | 1 |
865 | 2 |
866 | 1 |
867 | 4 |
868 | 1 |
869 | 2 |
870 | 3 |
871 | 1 |
872 | 2 |
873 | 1 |
874 | 2 |
875 | 3 |
876 | 2 |
877 | 2 |
878 | 4 |
879 | 1 |
880 | 3 |
881 | 2 |
882 | 2 |
883 | 4 |
884 | 2 |
885 | 4 |
886 | 2 |
887 | 4 |
888 | 6 |
889 | 2 |
890 | 3 |
891 | 2 |
892 | 5 |
893 | 6 |
894 | 2 |
895 | 2 |
896 | 2 |
897 | 1 |
898 | 5 |
899 | 5 |
900 | 2 |
901 | 6 |
902 | 2 |
903 | 3 |
904 | 6 |
905 | 1 |
906 | 6 |
907 | 2 |
908 | 5 |
909 | 3 |
910 | 3 |
911 | 4 |
912 | 4 |
913 | 4 |
914 | 3 |
915 | 4 |
916 | 2 |
917 | 4 |
918 | 4 |
919 | 3 |
920 | 3 |
921 | 6 |
922 | 4 |
923 | 3 |
924 | 4 |
925 | 3 |
926 | 4 |
927 | 2 |
928 | 2 |
929 | 3 |
930 | 2 |
931 | 6 |
932 | 1 |
933 | 2 |
934 | 4 |
935 | 2 |
936 | 2 |
937 | 4 |
938 | 2 |
939 | 3 |
940 | 2 |
941 | 3 |
942 | 1 |
943 | 2 |
944 | 3 |
945 | 4 |
946 | 4 |
947 | 6 |
948 | 1 |
949 | 6 |
950 | 2 |
951 | 2 |
952 | 5 |
953 | 5 |
954 | 3 |
955 | 4 |
956 | 3 |
957 | 3 |
958 | 6 |
959 | 6 |
960 | 2 |
961 | 5 |
962 | 2 |
963 | 1 |
964 | 3 |
965 | 6 |
966 | 2 |
967 | 2 |
968 | 3 |
969 | 3 |
970 | 1 |
971 | 3 |
972 | 5 |
973 | 2 |
974 | 2 |
975 | 5 |
976 | 1 |
977 | 3 |
978 | 2 |
979 | 2 |
980 | 6 |
981 | 4 |
982 | 4 |
983 | 2 |
984 | 3 |
985 | 2 |
986 | 2 |
987 | 2 |
988 | 3 |
989 | 4 |
990 | 6 |
991 | 2 |
992 | 4 |
993 | 3 |
994 | 2 |
995 | 4 |
996 | 2 |
997 | 2 |
998 | 4 |
999 | 3 |
1000 | 3 |
1001 | 5 |
1002 | 2 |
1003 | 4 |
1004 | 3 |
1005 | 4 |
1006 | 2 |
1007 | 2 |
1008 | 4 |
1009 | 2 |
1010 | 2 |
1011 | 3 |
1012 | 3 |
1013 | 3 |
1014 | 3 |
1015 | 4 |
1016 | 3 |
1017 | 1 |
1018 | 3 |
1019 | 3 |
1020 | 2 |
1021 | 4 |
1022 | 5 |
1023 | 4 |
1024 | 2 |
1025 | 3 |
1026 | 5 |
1027 | 3 |
1028 | 2 |
1029 | 4 |
1030 | 1 |
1031 | 4 |
1032 | 5 |
1033 | 4 |
1034 | 2 |
1035 | 3 |
1036 | 2 |
1037 | 3 |
1038 | 4 |
1039 | 1 |
1040 | 3 |
1041 | 1 |
1042 | 3 |
1043 | 3 |
1044 | 2 |
1045 | 2 |
1046 | 2 |
1047 | 1 |
1048 | 5 |
1049 | 1 |
1050 | 5 |
1051 | 2 |
1052 | 3 |
1053 | 4 |
1054 | 4 |
1055 | 4 |
1056 | 1 |
1057 | 3 |
1058 | 1 |
1059 | 4 |
1060 | 3 |
1061 | 5 |
1062 | 4 |
1063 | 2 |
1064 | 3 |
1065 | 1 |
1066 | 2 |
1067 | 4 |
1068 | 5 |
1069 | 5 |
1070 | 4 |
1071 | 5 |
1072 | 2 |
1073 | 3 |
1074 | 1 |
1075 | 2 |
1076 | 2 |
1077 | 4 |
1078 | 3 |
1079 | 5 |
1080 | 3 |
1081 | 2 |
1082 | 4 |
1083 | 4 |
1084 | 5 |
1085 | 1 |
1086 | 5 |
1087 | 4 |
1088 | 3 |
1089 | 1 |
1090 | 5 |
1091 | 4 |
1092 | 2 |
1093 | 4 |
1094 | 2 |
1095 | 1 |
1096 | 4 |
1097 | 2 |
1098 | 3 |
1099 | 2 |
1100 | 5 |
1101 | 3 |
1102 | 2 |
1103 | 4 |
1104 | 2 |
1105 | 5 |
1106 | 3 |
1107 | 6 |
1108 | 2 |
1109 | 3 |
1110 | 4 |
1111 | 3 |
1112 | 2 |
1113 | 2 |
1114 | 3 |
1115 | 3 |
1116 | 2 |
1117 | 5 |
1118 | 5 |
1119 | 3 |
1120 | 5 |
1121 | 3 |
1122 | 4 |
1123 | 2 |
1124 | 3 |
1125 | 4 |
1126 | 4 |
1127 | 5 |
1128 | 2 |
1129 | 1 |
1130 | 1 |
1131 | 2 |
1132 | 3 |
1133 | 3 |
1134 | 2 |
1135 | 3 |
1136 | 2 |
1137 | 4 |
1138 | 2 |
1139 | 5 |
1140 | 4 |
1141 | 2 |
1142 | 2 |
1143 | 3 |
1144 | 6 |
1145 | 6 |
1146 | 2 |
1147 | 6 |
1148 | 1 |
1149 | 4 |
1150 | 3 |
1151 | 1 |
1152 | 6 |
1153 | 5 |
1154 | 5 |
1155 | 2 |
1156 | 2 |
1157 | 3 |
1158 | 3 |
1159 | 3 |
1160 | 6 |
1161 | 2 |
1162 | 5 |
1163 | 4 |
1164 | 3 |
1165 | 2 |
1166 | 3 |
1167 | 3 |
1168 | 2 |
1169 | 3 |
1170 | 3 |
1171 | 3 |
1172 | 2 |
1173 | 2 |
1174 | 2 |
1175 | 3 |
1176 | 3 |
1177 | 2 |
1178 | 3 |
1179 | 3 |
1180 | 2 |
1181 | 2 |
1182 | 1 |
1183 | 3 |
1184 | 4 |
1185 | 4 |
1186 | 5 |
1187 | 6 |
1188 | 2 |
1189 | 3 |
1190 | 3 |
1191 | 3 |
1192 | 3 |
1193 | 6 |
1194 | 1 |
1195 | 4 |
1196 | 5 |
1197 | 5 |
1198 | 1 |
1199 | 3 |
1200 | 2 |
1201 | 2 |
1202 | 4 |
1203 | 1 |
1204 | 1 |
1205 | 3 |
1206 | 4 |
1207 | 2 |
1208 | 2 |
1209 | 5 |
1210 | 4 |
1211 | 2 |
1212 | 1 |
1213 | 1 |
1214 | 2 |
1215 | 3 |
1216 | 3 |
1217 | 2 |
1218 | 4 |
1219 | 4 |
1220 | 5 |
1221 | 5 |
1222 | 3 |
1223 | 1 |
1224 | 3 |
1225 | 3 |
1226 | 5 |
1227 | 2 |
1228 | 1 |
1229 | 4 |
1230 | 2 |
1231 | 5 |
1232 | 3 |
1233 | 4 |
1234 | 2 |
1235 | 4 |
1236 | 2 |
1237 | 4 |
1238 | 1 |
1239 | 1 |
1240 | 5 |
1241 | 3 |
1242 | 3 |
1243 | 1 |
1244 | 2 |
1245 | 4 |
1246 | 1 |
1247 | 7 |
1248 | 4 |
1249 | 1 |
1250 | 4 |
1251 | 5 |
1252 | 2 |
1253 | 1 |
1254 | 2 |
1255 | 3 |
1256 | 2 |
1257 | 2 |
1258 | 1 |
1259 | 2 |
1260 | 1 |
1261 | 4 |
1262 | 6 |
1263 | 5 |
1264 | 3 |
1265 | 1 |
