I set something up for someone else so click this link and
see it work.
http://www.grainge.org/test/cshcall/startpage.htm#csh.htm
For help on your local drive, the call would then be
something like
file:///C:/rh7_test/!SSL!/WebHelp/startpage.htm#csh.htm
With this method you are not using the RoboHelp_CSH.js file.
Is that something you have added to the source or to the output.
Create a simple project that has a default topic and a topic
that you want to call when opening the help, call that Context
topic as I have in the example. When you generate the help locally,
change the start page name in the wizard to startpage.htm. That way
you have startpage.htm, default.htm and csh.htm. Makes it simple to
see what is going on.
