I used to be able to simply sign digitally by going to "fill and sign", "place signature", then drag new signature box, then it would ask for a password, then it would ask me to save the file and then I would have a signed, locked document. My hard drive was replaced and I am trying to recreate that capability. How do I do that?
Hi larryf68710395,
Try to follow below mention steps:
1- Launch Reader or Acrobat>click Edit>Preferences>Signatures>Identities & Trusted Certificates>More
2- Under Digital IDs( in the top left corner) >Add ID>select A new digital ID I want to create now>Next
3- New PKCS#12 digital ID file>Next
4- Enter your identity information like Name, Email Address > Next
5- Enter the password for the digital ID>Finish> close the window
Let me know if you face any issue while following the steps.
Thank You,
Shivam
Shivam
Thank you, this was very helpful.
Can I customize the certificate?
Is there a way to import my signature which I have in a jpeg file to use with the signature?
Larry
Hi larryf68710395,
I am sorry for the delay in response.
Yes, you can customize the certificate, please follow below mention steps to do so:
1- Under Edit>Preferences>Signatures>Creation & Appearance>click More
2- Under Appearances( in the bottom corner)>select the ID you want to change appearance for>Click Edit
3- Under Configure graphic>select Imported graphic>click File>Browse to the file you want to add.
Let me know if you have further questions.
Thank You,
Shivam
