Hi, I insert hyperlinks in a large file and finaly export to pdf. The pdf will be open via a weblink. I need that the url hyperlink will be open in a new page/tab.
In the past, I read the answer was a javascript in the pdf file. It does not work in cc 2017. We need a solotion in indesign, because we update the file often, each time export again to pdf. Please help!
Thank you Ayala
There is no solution in InDesign. As far as I know, there has never been an answer in InDesign. It has to be done in Acrobat Pro with JavaScript.
Thank you!!!
we tried but java script did not work onacrobat cc 2017.
There is no Acrobat CC 2017. The current version is Acrobat DC.
You'll need to ask in the Acrobat forums.
Thank you Steve
I will ask there
