.AEC files from Cinema 4D will not import into After Effects CC 2015. I have the correct exchange files and it used to work just fine, It imports it but when imported it doesnt show my file in the library and it doesnt give me any error message. What do i do?
AE version is CC 2015, Im trying to import a 10 second 30 FPS 300 Frames PNG Sequence with a camera from cinema 4d.
PNG Sequence
Your problem is here. PNG support is buggy in current AE versions. Use a different format.
Mylenium
any information on the nature of that PNG bug? I have not found any post or article about a PNG problem in Ae and it works fine on my Windows machine but maybe it's a certain combination I have yet to encounter. please provide more information if you have any.
It actually isn't, I can import the PNG sequence just fine, It just doesnt import the camera along with it. Even if i use .AEC files that used to work just fine it doesn't work anymore.
This didnt fix it, Thanks for the response though!
Hi KoenD,
Did you ever solve this issue? We're hopeful that you did. If so, give details. If not, let us know so we can help you out.
Kevin
