Html5Canvas
Jan 01, 2017 Jan 01, 2017
hi ,
    i am using adobe animate cc ..i have problem in using html5canvas while publish in html some times its not working properly and when i use images in file its not working in chrome and internet explorer , i missing something i dont  know what am missing ,Html5canvas file is not working in offline its working only when have internet connection  ...can u pls anyone help ..
  Thanks in advance .
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from Comments forum to specific Program forum... Mod]
7.0K
LEGEND , Jan 02, 2017 Jan 02, 2017
You should have been opening the developer console in Chrome to see if there are any error messages.
Go into your publish settings and disable spritesheets, if it's still enabled.
is it working in any browser?
have your uploaded your files to a server?  if so, what's the url to your html page?
hi ...its working fine in firefox and latest internet explorer ,but it is not working in chrome ,when i replace with vector instead of images then its working ..i cant control through code while opened in chrome browser ..i attached a link of my files  ,plz help ..thanks in advance .. Dropbox - JS.rar
Advocate ,
"Html5canvas file is not working in offline its working only when have internet connection"
This is probably because by default, your published files will reference the CDN-hosted versions of the CreateJS libraries, which requires an internet connection.
In Publish Settings > Advanced, you can uncheck "Hosted Libraries" to publish a copy locally and reference that instead.
thank you for your reply.....no its not working ..if i dont have a internet connection while publishing its showing blank page  in browser...plz help thanks in advance
click file>publish settings>advanced>untick 'hosted libraries' as suggested in message 2.
Apr 08, 2022 Apr 08, 2022
We are having the same issues (April 2022) and this did not solve the problem.
And also when i import a image in stage and convert to movieclip and add event to a moviclip , and published means not working in chrome ,but working in firefox ...i dont know what to do ..plz help
Jan 03, 2017 Jan 03, 2017
In developer console its showing error ..."Uncaught An error has occurred. This is most likely due to security restrictions on reading canvas pixel data with local or cross-domain images." can u say the solution for this problem ...thanks in advance
Advocate ,
The solutions have already been given.  Go to File > Publish Settings > Sprite Sheets, and uncheck "Combine image assets into sprite sheets".
For your other issue where things aren't working without an internet connection, in File > Publish Settings > Advanced, uncheck "Hosted Libraries".
Then save and re-publish.
i did everything which you said ..but its not code working in chrome ...showing above error ..shall i send a file ..can u check it
Advocate ,
Sure, share your file.  The previous file you shared on Dropbox did not have the correct publish settings.
Dropbox - work.rar ..this file works fine in firefox ,but in chrome and internet explorer is not working ,In chrome file viewing in IE not viewing also ..
Advocate ,
So in addition to the other two issues, it's also this:
Error about cross-domain images · Issue #726 · CreateJS/EaselJS · GitHub
canvas - createjs button in flash is not working - Stack Overflow
html5 - EaselJs errors in chrome - Stack Overflow
For your click events, creating invisible buttons on separate layers instead of directly targeting the movieclips with images in them should fix the local viewing issues in Chrome.
Otherwise, it should be fine when uploaded to a server either way.
Mar 13, 2017 Mar 13, 2017
Hi there,
You´re right, I had the same problem parsing an XML from Adobe AnimateCC 2017 version 16.0.0.112.
The error on console is "Uncaught An error has occurred. This is most likely due to security restrictions on reading canvas pixel data with local or cross-domain images."
Althought you can think it has to be with images of domains, I think It has to be with mouse events, once I used and invisible button (as in the Flash old times!) it disappeared. I didn´t have to change any Chrome Security settings
Regards
