placed files with transparency outputting to pdf with error on page
Dec 31, 2016 Dec 31, 2016
This problem just started recently. Imported pdfs with transparency are outputting to pdfs with error. I'm using indesign 2016. Sometimes the transparent background simply drops out and does not appear in the pdf. I am using these output prefs: http://www.publicationprinters.com/Files/IndesignCS2-CC.pdf
thanks
790
Jan 01, 2017 Jan 01, 2017
You should give us more information on those PDFs which you have imported.
On Sun, Jan 1, 2017 at 4:09 AM Willi Adelberger <forums_noreply@adobe.com>
Your reply is blank.
What info do you need on the imported PDFs? They are cmyk or greyscale, ads that are sent in by customers. Its sometimes the backgrounds or a logo that drops out and seems to be limited to those pdfs that contain transparent objects. They look fine in the original PDF but when I import them into the indesign file and export them with Compatibility set to Acrobat 5 (PDF 1.4) (which does not flatten) I'm getting intermittent drop outs.
I can upload some examples or problem files, but I can not upload a pdf here in this reply. Is there a place to do that?
thank you
Does it happen if you export using the PDF/X-4 preset?
You have to use a file sharing service like Dropbox or Adobe Cloud to share files
It happens using Acrobat 5 (PDF 1.4) compatibility
Here is the summary text of my PDF export settings:
Description
    Use these settings to create Adobe PDF documents for quality printing on desktop printers and proofers.  Created PDF documents can be opened with Acrobat and Adobe Reader 5.0 and later.
PDF Preset: PubPrinters
Compatibility: Acrobat 5 (PDF 1.4)
Standards Compliance: None
General
    Pages: All
    Spreads: Off
    View: Default
    Layout: Default
    Full Screen: Off
    Generate Thumbnails: Off
    Optimize PDF: Off
    Create Acrobat Layers: N/A
    Export Layers: Visible and Printable Layers
    Include Bookmarks: Off
    Include Hyperlinks: Off
    Export Nonprinting Objects: Off
    Export Visible Guides and Baseline Grids: Off
    Create Tagged PDF: Off
    Interactive Elements: Do Not Include
Compression
    Color Images
        Bicubic Downsample at: 300 ppi
        for images above: 300 ppi
        Compression: Automatic
        Tile Size: N/A
        Quality: Maximum
    Grayscale Images
        Tile Size: N/A
        Quality: Maximum
    Monochrome Images
        Bicubic Downsample at: 1200 ppi
        for images above: 1200 ppi
        Compression: CCITT Group 4
    Compress Text and Line Art: On
    Crop Image Data to Frames: On
Marks and Bleeds
    Crop Marks: Off
    Bleed Marks: Off
    Registration Marks: Off
    Color Bars: Off
    Page Information: Off
    Page Mark Type: Default
    Weight: 0.25 pt
    Offset: 0p6
    Use Document Bleed Settings: Off
    Bleed Top: 1p6
    Bleed Bottom: 1p6
    Bleed Left: 1p6
    Bleed Right: 1p6
    Include Slug Area: Off
Output
    Color Conversion: Convert to Destination (Preserve Numbers)
    Destination: U.S. Web Coated (SWOP) v2
    Profile Inclusion Policy: Don't Include Profiles
    Simulate Overprint: N/A
    Output Intent Profile Name: N/A
    Output Condition: N/A
    Output Condition Identifier: N/A
    Registry Name: N/A
Advanced
    Subset Fonts Below: 100%
    Omit PDF: Off
    Omit EPS: Off
    Omit Bitmap Images: Off
    Transparency Flattener Preset: N/A
    Ignore Spread Overrides: N/A
    Display Title: File Name
    Language: English: USA
Security
    N/A
Warnings
Right, I get that the printer is recommending those preset settings, but it seems that the relatively ancient (2001!) Acrobat 5 Compatibility setting is causing problems.
The printer claims to be using state of the art equipment, so surely they can handle the Adobe recommended PDF/X-4 preset, or at least Acrobat 7. You can export to PDF/X-4 and force all of the color into a single CMYK space by selecting the PDF/X-4 preset and setting the Output panel to their recommendations.
At Publication Printers Corp., we provide superior printing services using state-of-the-art technology.
Ok. What the prepress guy told me was to try a later acrobat compatibility setting. He also said they recommend Acrobat 5 because customers who use spot colors can have problems. We don't use spot colors at all so shouldn't be an issue. Should I use the latest version? Are there pros & cons? Thanks
Sent from my iPhone
Jan 02, 2017 Jan 02, 2017
If you place PDFs in InDesign it is always the best to use PDF/X-4 regardless what the final output of the file will be.
I assume you can't control how the provided PDFs are created, so export using Acrobat 7 then preflight and proof your PDF before sending it out. There's no foolproof PDF preset, so you should always check the PDF.
Ok - over the next few months I will experiment and see what works - thanks!
If you require PDFs from you clients, require PDF/X-4 with RGB or Greyscale Images and live transparency. If they bring you printed PDFs or PDF 1.3 (like X-1a or X-3) you will experience problems with transparency.
