Is there a way to open more than one navigator windows or is there a plug-in for that. I found nothing. Thank you in advance!
Not that I know of. If you need the see two locations on the same document, go to Window menu > Arrange > New Window for Image.psd,
There you can set Window > Arrange > 2 up vertically and use the Navigator to set location and zoom independently for the two views of the same document.
Gene
Gene
That's not exactly what I was asking for but I can go with it. Thank you!
The navigator always controls the active Image.
I don't Think you can open multiple Navigators.Why would you want to?
Gene's advice is the only way that I know of, but other than zoom size and position, I can't think what the advantage might be. For instance, you can't have one window showing a flipped view while the others are not flipped.
Do you know about spring loaded Pan? Hold down the h key and click on zoomed in image, and the view will temporarily show the full canvas with a bounding box showing the zoom limits. Reposition and let go with the mouse, and you have a supercharged version of the Pan tool.
Didn't knew about that. Thank you!
