Title behind a crowd of people
Jan 02, 2017 Jan 02, 2017
Hi there,
I have footage of a dance performance on stage that I would like to add a title to. The footage begins on a fairly dark stage with a purple background screen, the dancers enter onto the stage as silhouettes in front of the screen. I would like to add the title of the dance onto the purple screen behind the dancers. How would I go about doing this?
507
If you cannot pull a procedural matte then you are stuck with rotoscope. Rotoscope, especially with multiple subjects in the shot, going to be a long and tedious process.
A procedural matte is using a procedure like Keylight or by adjusting the channel values to create a hight contrast matte that can be used to separate foreground and background elements. Without seeing at least a typical frame from your shot it is impossible to give you a step by step solution. If there is enough contrast and the footage is significantly free of compression artifacts you may be able to pull a procedural matte of some kind.
From the way your question was worded I think you may be new to After Effects. Either technique will require some research and practice. Don't expect a one click solution.
I have worked with Premiere for a while now however I am new to After Effects, thank you for your help
Show is a frame of your movie and we can probably point you directly to a solution. If you are on windows just press the Print Screen button and then paste into the reply field of this forum. If you are on a Mac then Ctrl/Cmnd + Shift + 3 and drag the screenshot into the reply field. Takes about 2 seconds.
Looks like rotoscoping is the only option you have
Or put it on the upper 2/3 of the magenta screen.  It's magenta, not purple.
Adobe Employee ,
Feb 06, 2017 Feb 06, 2017
Hi FlorianD,
What did you end up doing to create your effect? Did any of the suggestions our experts made help you out? Please let us know.
Kevin
