script to arrange table
Participant ,
Jan 02, 2017 Jan 02, 2017
I have 5 tables in single page arranged vertically, is there any script to arrange them with equal vertical space between them...
678
Community Expert , Jan 02, 2017 Jan 02, 2017
abhijeett89122812 wrote:
… they are three different tables... any other solution for this.
Hi together,
If I understand abhijeett right:
Three different text frames with three tables positioned on top of a graphic frame?
Then abhijeett already had the solution.
Unfortunately only sort of.
( One cannot trust the helpx pages these days… )
The helpx page is not showing the optional controls of the Align Panel abhijeett is needing.
Align and distribute objects in InDesign
First make the options visible:
But
Guide ,
you don't need a script.
There are various ways to do this depend on how did you placed the tables in your page
if the tables are in separated frames  you could use "align and distribute" option
if the tables flow with the text you could use space before/after option
Are all the tables in one text frame?
If yes and there are only the tables in the frame you could use InDesign's Text Frame Options dialog to solve this problem:
Before:
After:
( From my German InDesign )
Vertical Justification > Justification [Justify]
Uwe
Participant ,
no there are not in single text frame, they are three different tables... any other solution for this.
thanks in advance
Guide ,
as I said above
if the tables are in separated frames, select them all and  use "align and distribute" option (with "use spacing" or without)
Hi together,
But before doing the vertical alignment with the Align Panel:
1. Select all three text frames
2. and fit frames to contents.
Then distribute vertically.
Select the text frames:
Fit frame to contents:
Distribute vertically:
Uwe
Participant ,
Thanks, it is the best solution for my problem...
My conclusion is and still remains:
InDesign's helpx pages could need a lot of professional help.
( I decided not to get angry about this so early in the new year. )
Cheers,
Uwe
