Hi there,
I'm doing an animation using the Plexus plugin - something similar to this:
Intro with Plexus plugin After Effects tutorial - YouTube
But I want to animate the lines not with the camera (like in the tutorial) but with an effect in the plexus effects panel (points on each mask). If I change the value, my poligons are being animated. But - I want the animation to loop seamlessly. If I copy the first frame and put it at the end of the timeline, the animation goes back in the wrong direction. I would like to have the first and last keyframe the same + a keyframe in the middle with a different value, so that the animation plays on, but seamlesly, without changing the direction.
I guess I'm explaining it wrong but I don't know how to do it better. So the basic problem is - can I change the direction of the animation if what I'm animating is just a value in the effects panel?
If you can't nest your composition in a new composition and then use time remapping to reverse the action you will have to render a DI (digital intermediate) using a suitable production format and then timeremap or time reverse the clip. Many simulation plug-ins will not work when time remapping a nested comp so this may be your only option. I have not done any specific testing of Plexus but the DI route will always work.
thanks, I'll try that
