i have never needed to use an autosuggest with numeric
values, so not
sure if any of this works, but see if this helps you as a
work-around
until the bug is fixed by Adobe:
1) use your db's equivalent of CAST() function to convert
your numeric
value to a string in the query that populates your
autosuggest field
2) use your db's string concatenation function/syntax to add
a space [or
some other character] in front of your numeric values to turn
them into
strings (don't forget to trim that character from the
autosuggest field
value when the form is submitted)
hth
Azadi Saryev
Sabai-dee.com
http://www.sabai-dee.com/
