Hey all, I'm having trouble recreating some image edits I made a couple weeks ago.
Here is an original image:
I was able to create the effect in the image below using Duplicate Layer > Filter > Filter Gallery > Neon Glow > Glow Size: 4 > Glow Brightness: 18 Glow Color: #ff5a00 > Top Layer Mode: Overlay
After trying to recreate this I get images that look like this:
Anyone know what's going on? Any help is appreciated, thanks!
I've got pretty close. Do exactly what you said with all the same settings. Then invert the top layer (Ctrl i — Cmd i)
I'm guessing that you had other adjustment layer(s) further up the stack, and probably some masking. Does that sound feasible?
It's feasible but I also tried that as well. The only adjustments that I would have made would be in RGB Curves but I even tried that and it doesn't produce the same results.
Does it help to reduce opacity of your filter layer? Have you tried Soft Light blend mode?
I have also tried changing the opacity but that of course just makes it lighter and doesn't create that dark look. I'll try Soft Light specifically again but I know I tried different blending modes too.
Trevor
When I invert I get a green looking filter (which makes sense since inverting orange would get you a greenish right?)
Thanks for all the help so far about this, it's super confusing!
Unless something has changed recently, I remember that Filter Gallery's Neon Glow is a random filter. You can repeat the exact same process multiple times on the same image and end up with different results each time.
Nancy
