we'd like to fix a validation in Script to identify the anchored objects which are overlapping while running the script, The below code is working for most of the cases but if i have more than five query in a para its not working. could anyone advise on this?
var myDoc = app.activeDocument;
myDoc.preflightOptions.preflightOff = true;
myDoc.viewPreferences.horizontalMeasurementUnits = MeasurementUnits.points;
myDoc.viewPreferences.verticalMeasurementUnits = MeasurementUnits.points;
myDoc.viewPreferences.rulerOrigin = RulerOrigin.PAGE_ORIGIN;
myDoc.zeroPoint = [0,0];
var myAllNotesArray = myDoc.stories.everyItem().notes.everyItem().getElements(), myNotesBasealign , myPage, myNotes , myNotetextframe = [];
var pageLeft = myDoc.pages[0].marginPreferences.right - 9;
var pageRight = myDoc.pages[0].marginPreferences.left - 9;
try{if (myDoc.paragraphStyles.item('AuthorQueries') == null) { var AuthorQueries = myDoc .paragraphStyles.add({name:'AuthorQueries', appliedFont:"Times LT Std", pointSize:6, leading:7});}} catch (e){ }
authorQueryPlacement()
checkstackOrder()
spineRelative()
avoidOversetspineRelative()
function checkstackOrder()
if (myNotetextframe != null)
for (var i =0;i<myNotetextframe.length;i++)
for (var j =i+1;j<myNotetextframe.length;j++)
if (touches(myNotetextframe, myNotetextframe
myNotetextframe
} // fn close
function spineRelative()
if (myNotetextframe.anchoredObjectSettings.spineRelative==false)
if (myNotetextframe.geometricBounds[2] > myNotetextframe
var diff = myNotetextframe.geometricBounds[2] - myNotetextframe
mydiff = (myNotetextframe
myNotetextframe
break;
} // fn close
function touches(bounds1, bounds2)
if (bounds1.geometricBounds[2] < bounds2.geometricBounds[0]) return false;
if (bounds1.geometricBounds[0] > bounds2.geometricBounds[2]) return false;
if (bounds1.geometricBounds[1] > bounds2.geometricBounds[3]) return false;
if (bounds1.geometricBounds[3] < bounds2.geometricBounds[1]) return false;
return true;
function authorQueryPlacement()
for(i=0; i<myAllNotesArray.length;i++)
if (myAllNotesArray.texts[0] != '' )
myPage = myAllNotesArray.storyOffset.insertionPoints[0].parentTextFrames[0].parentPage.name;
myNotes = myAllNotesArray.storyOffset.insertionPoints[0].textFrames.add({geometricBounds:[0,0,pageLeft,pageLeft]});
myNotes.anchoredObjectSettings.anchoredPosition=AnchorPosition.anchored;
myNotes.anchoredObjectSettings.horizontalReferencePoint = AnchoredRelativeTo.TEXT_FRAME;
myNotes.anchoredObjectSettings.verticalReferencePoint = VerticallyRelativeTo.capheight;
myNotes.anchoredObjectSettings.anchorXoffset=+5.5
myAllNotesArray.texts[0].duplicate(LocationOptions.AFTER,myNotes.parentStory.texts[0].insertionPoints[0]);
myNotes.paragraphs[0].applyParagraphStyle(myDoc.paragraphStyles.itemByName("AuthorQueries"));
myNotes.textFramePreferences.autoSizingReferencePoint = AutoSizingReferenceEnum.TOP_CENTER_POINT;
myNotes.textFramePreferences.autoSizingType = AutoSizingTypeEnum.HEIGHT_ONLY;
myNotes.anchoredObjectSettings.spineRelative=true;
delEndEnterMark(myNotes)
myNotes.textFramePreferences.autoSizingType = AutoSizingTypeEnum.OFF;
myNotes.fit(FitOptions.FRAME_TO_CONTENT);
app.select(myNotes)
frameHeight = app.selection[0].geometricBounds[2] - app.selection[0].geometricBounds[0]
myNotes.anchoredObjectSettings.anchorYoffset=+ frameHeight;
myNotetextframe.push(myNotes);
Any idea or logic to clear the anchor overlap?
Can you send us a test file?
Herewith i have attached file for your reference.
On Wed, Jan 4, 2017 at 6:11 PM, Obi-wan Kenobi <forums_noreply@adobe.com>
sent
Where?
Make a dropbox or wetransfer file!
Any suggestion
Hi Kenyank
1) When you post code please use the advanced editor (link on the top right of the reply box) so you can format your code and have is semi-readable.
To format it click on the >> next to the Syntax Highlighting > Java or JavasScript
2) A screenshot or 2 can be very usefull
If you can send a link by https://wetransfer.com/ it would be good but it look's like they've got an outage right now.
Below is Your code formatted.
Sadly formatting it will not make it work so it still won't work but at least it will be a bit more inviting for people to look at.
myDoc.zeroPoint = [0, 0];
myNotesBasealign, myPage, myNotes, myNotetextframe = [];
try {
var AuthorQueries = myDoc.paragraphStyles.add({
appliedFont: "Times LT Std",
pointSize: 6,
leading: 7
} catch (e) {}
checkstackOrder()
spineRelative()
function checkstackOrder() {
if (myNotetextframe != null) {
for (var i = 0; i < myNotetextframe.length; i++) {
for (var j = i + 1; j < myNotetextframe.length; j++) {
) == true) { myNotetextframe
.anchoredObjectSettings.spineRelative = false; }
} // fn close
function spineRelative() {
if (myNotetextframe.anchoredObjectSettings.spineRelative == false) {
) == true) { if (myNotetextframe.geometricBounds[2] > myNotetextframe
.geometricBounds[0]) { var diff = myNotetextframe.geometricBounds[2] - myNotetextframe
.geometricBounds[0] mydiff = (myNotetextframe
.anchoredObjectSettings.anchorYoffset) + (diff + 12) myNotetextframe
.anchoredObjectSettings.anchorYoffset = mydiff; }
break;
} // fn close
function touches(bounds1, bounds2) {
return true;
function authorQueryPlacement() {
for (i = 0; i < myAllNotesArray.length; i++) {
if (myAllNotesArray.texts[0] != '') {
geometricBounds: [0, 0, pageLeft, pageLeft]
myNotes.anchoredObjectSettings.anchoredPosition = AnchorPosition.anchored;
myNotes.anchoredObjectSettings.anchorXoffset = +5.5
myAllNotesArray.texts[0].duplicate(LocationOptions.AFTER, myNotes.parentStory.texts[0].insertionPoints[0]);
myNotes.paragraphs[0].applyParagraphStyle(myDoc.paragraphStyles.itemByName("AuthorQueries "));
myNotes.anchoredObjectSettings.spineRelative = true;
app.select(myNotes)
myNotes.anchoredObjectSettings.anchorYoffset = +frameHeight;
