is there a best way to resize and crop and image?
i have a 30.5"x12.5" image at 300ppi and i want to resize to 48"x24" at 300ppi
I compared setting the resolution and dimensions using the crop tool vs using the upsampling tool and i don't really see much difference.
are they both doing the same thing?
thanks
Resampling with the Crop Tool uses the Interpolation Method specified under Preferences > General > Image Interpolation while Image > Image Size (which I suspect you might mean by »upsampling tool«) allows to set the method individually.
If you should have meant Edit > Transform then you can also select the method individually (in the Options Bar) but »Preserve Details« is not available there.
