I've noticed this before, but am now wondering if anyone else is annoyed by this, or better yet if they have a work arround for it?
Issue:
When working on long / complex animations within AE, I tend to set the comp render / downsample to Auto and work at half res, or lower, when I'm just getting the timing blocked out, and have not begun finessing fine details.
All is well within AE, but when using the dynamic link option and placing in the WIP animation in Premiere [ where I can make better assessment of audio cues, and cut it in context], the footage size changes to whatever the 'current settings' downsampling is set to within AE.
Does anyone know a way to prevent this, without a whole lot of babysitting either in AE or Prem?
Its particularly annoying on complex collaborative work, where say I'm animating on a high priority project where an editor is working with my dynamic link files while the paint is still wet, and I'm making changes - at whatever downsample I need at the time.
Suggestion:
This seems like a setting that should have a global override, either within Premiere, or AE. If in Premiere, the dynamic link render could autoscale to the comp size.
Preferably, its an AE preference box, that lets the user override 'current settings' for downsampling when handing off to dynamic links.
I tend to use dynamic link for the early stages of development, getting thru a few rounds of revisions, and then do final renders to get things archival before wrapping up the project, as they can get pretty heavy with motion blur, grain and other CPU/GPU expensive tools.
I do this either with a 'render and replace' within Prem [ so far so good, its an awesome workflow addition for me], or trusty dusty render queue.
Which BTW has render settings that have always been able to override, or go along with 'current settings', which have included downsampling.
I guess my short version of the question is " why can't dynamic links have the same functionality?"
Sorry for the long post!
Cheers and Happy New Year everyone
Select the clip, and chose from the menu 'clip/video options/ scale to frame size'.
don't. you are downgrading your image. this is a bug in the current version and the workaround is there: Known issues in After Effects CC 2017
DOH. After spending so long writing that, I just found a workaround that seems to be OK, within Premiere.
This accomplishes my Premiere suggestion, and just blows up the AE dynamic link file to fit the frame size.
Decent work around, but still requires vigilance /babysitting if doing a 'render and replace' within Premiere.
Anyone else agree that an AE pref would still be the way to go?
D
and PS, I'm using Prem 2017.0.1, and AE 2017.0, on a Mac OSX 10.11.6
roeiyossef​- Thanks! I should remember to check that known issues list before posting anything here!
By all means, I'm not suggesting that the 'scale clip to frame size' is a solution, or that you would want to use this for finals.
Just simply a way to have temp work display correctly [ albeit at a low resolution] while you are working.
And FYI, I tested the 'Render and replace' feature in this situation, and the render was downsampled [IE it is not able to do a 'full quality' override]... So be vigilant of your renders.
Well I'm glad it's a known issue, and I hope Adobe will make changes similar to my suggestions at the top of this thread.
Kevin-Monahan​, any ideas?
Thanks for the link
For anyone who is looking at this, my 'workaround' for displaying temp comps full frame size via 'scale to frame size' is highly unadvisable- even just for temps!
Its not an effect that can easily be removed in bulk via 'remove attributes'; and if you are working in Premiere with any subsampling to increase playback performance, it becomes very buggy and unstable. I retract my previous post on the issue!
I'm hoping that someone can write a script for AE that can batch set comp subsampling to 1:1, using something similar to rd_CompSetter, which comes painfully close to doing so already
Best,
D
davidh45788218 , Roei Tzoref , I just posted a notice here:
New Script workaround for the Dynamic link Resolution issue, CC2017
Saved by redefinery . Thanks Jeff!
http://www.redefinery.com/ae/view.php?item=rd_CompSetter
redefinery.com: rd: Composition Setter
All the best- and good luck
Does anyone know when this will be fixed? I have projects with dozens of linked comps and it takes way too long with the workaround.
Darn- I thought this insanely useful script might be of some help for you, but it does not appear to have a 'subsampling' render settings controls..
Lots of really amazing scripts in here though, and perhaps someone can find an AE script based workaround for a "Set all comp subsampling to 1:1" , or the like.
Got to get back to work, but good luck!
