I have a series of layered images that I want to toggle on and off; think a map with layers of roads, cities, rivers, etc.
This is in an html 5 canvas.
A separate button for each layer.
I could do this with AS2 and very easily with Animate Edge, but I'm spinning my wheels in Animate CC.
Anyone have a code snippet I could start with?
Many Thanks, m
i don't download and correct files unless hired.
here's a working example that you can start with: http://www.kglad.com/Files/forums/toggle.html
convert each to a movieclip, assign an instance name and use the visible property of html5 movieclips:
this.roads_btn.addEventListener('click',roadsF.bind(this));
function roadsF(){
this.roads_mc.visible=!this.roads_mc.visible;
Mmmm, can't get that to work.
I made the layer image an instance (called roads) of a movie clip symbol (called roads); I made the button a button symbol.
I attached the action to the button at the scene level.
My test file is: http://www.grafport.com/toggletest01.fla
I really appreciate the help, m
This sort of thing works almost exactly like in AS2.
Can you get clips to disappear by hard-coding a toggle of the .visible property?
Have you verified that your button event handlers are firing with console.log() statements?
You have to narrow down exactly what the point of failure is.
Thank you! I see where I failed; I tried to attach the action to the button rather than the frame. I can run with this now.
Sorry if I appeared to be asking for spec work, I really just wanted the concept, not for you to do it for me. Thanks again, m
you're welcome.
if you're going to do more than a negligible amount of work with html5, it's helpful to setup a debugging scheme. there are lots of them depending on which browser you like to use. they allow you to pinpoint problems instead of guessing why something is failing.
i like firefox so i use the firebug plugin for debugging.
