Muy buenos días
En buscar y reemplazar necesito reemplazar un código en varias páginas al tiempo (todas tienen el mismo código), el código es largo y cuando lo pego en la ventana de buscar y reemplazar no lo coloca todo solo coloca una lineas... porque??... es posible modificar la cantidad de lineas que haceptan las ventanas de buscar y reemplazar??
This version has a limit of 1232 characters in the Replace field. I filed a bug report below.
Find & Replace Character Limit – Adobe Dreamweaver CC: Feature Ideas
Also in the Ideas section.
Hi jorgev,
I did not quite get your question but from what I did, it looks like you are trying to replace code using Find and Replace. Because there have been changes to the Find and Replace functionality in 2017, can you let us know the version of DW that you are currently using? Also, is this issue that you mention seen only in the latest version?
Preran
How many characters are you trying to replace?
There is a character limit in the Replace field.
Nancy
Hi
i have the last version Dreamwaver 2017.0.1.
In dreamweaver cc6 i cant put any lines of code, but the last version only no.
Thanks for report the bug...
