My marquee tool displays as a draw a box etc but then disappears until i zoom in and out
my blending modes won't update unless i click on the image meaning i can't quickly flick through them
when i drag in a picture it isn't visible until i move it ,when i turn off a layer i have to click on the image to get it to update and disappear
the main problem is that my image doesn't listen to my layers panel until i once again click on the image which wastes allot of time, i would like to be able to flick layers on and off and view whats happening in real time rather than constantly clicking between the two panels.
can i fix these issues?
[Moved from non-technical Forum Lounge to specific Program forum... Mod]
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
I have a few ideas for you;
1. Try updating your video driver.
2. Try disabling GPU acceleration in Photoshop Preferences
3. Try resetting Photoshop Preferences to the default (corrupt preference data can make Photoshop behave strangely).
In order for us to help, it would be useful to know your Photoshop version number, your OS and OS version number, etc.
Mike
also my text doesnt update in real time i have to click off the box to see what i have typed or deleted
Mike
Thanks a tone for the quick reply
I've tried the disabling the GPU and it appeared to do nothing, i may need to update the video drive though.
It's Photoshop CC 2017, this is my mates laptop not mine by the way so im not sure about changing the preferences but i messaged him and he said it's should be on the default anyway.
This is a windows 7 laptop with a 64 bit operating system with an intel core i5-3320M CPU and 8 GB of RAM (thought i'd give you as much info as i can incase it helps)
It could be the video drive, sorry if this is a naive question but if I update them will it change anything on the laptop because as i said this is my mates and I may have to return it to him one day
Probably will help him in the long run.
Go to the laptop manufacture and see if there are any video updates.
Should be automatic for you.
Jim
product version 18.0.1 by the way
Mikey,
Sorry I forgot to include a link for resetting the preferences:
While the preferences may indeed be set to default, they can sometimes become corrupt. Resetting clears the problem. Instructions are available on the page I've linked here.
Mike
I've tried it didn't change anything unfortunately, is it to do with my graphics card? It's a Intel HD Graphics 4000 and it says it's up to date, or is it the fact it's on windows 7 because someone else's laptop has windows 8 and it runs normally
Nobody knows. Really, nobody knows. What we are giving you are the things that most often work, are easiest to do (or sometimes, easiest to recommend). When you've tried these we don't have much else in the armoury. And yes, there is a risk to your system from these.
One key thing: never say something's up to date because you let software check for updates. Automatic updates often fail and this is a very common source of problems that are easily solved (once someone eventually stops saying it's up to date and checks). Get actual, precise, version numbers and quote or check them.
