Hi!
Trying to figure out how to slow down just a small section of a video in Captivate 9. It's a cpvc project.
I don't want to slow the entire video down. Just one segment.
OK - that's good news! What you want to do is actually slow down the action on the screen - to allow the user to clearly see each step in a process, right?
Captivate can't stretch a video segment or slow it down. What you can do is create extra time between each action by inserting static screenshots into the cpvc timeline and splitting the video into segments. For example, see the screenshot below.
All I did was take a shot of the video right where I split it and inserted the image into the time
...Copy link to clipboard
What's the purpose of slowing it down? Are you showing a screen shot of something and need more time to explain what is there?
(If the above is the reason to slow it down, take a shot of the screen, split the movie and insert the static image for as long as keep your narration in sync with what's happening on the screen.) If not - please explain a little more.
It’s a video demo of using some software. It’s not just a screenshot. I’d rather not re-record the video if I don’t have to do so.
The purpose of slowing it down is just to allow the viewer to see things better. Right now the video in this one section is just a little too fast.
Thanks.
Is there a narration track embedded in your cpvc?
There is no narration track yet. I was going to add one later.
Thanks for the help!
All I did was take a shot of the video right where I split it and inserted the image into the timeline. This extended the view of that moment for another three seconds (my decision - can be as long or short as necessary) and gave me time to add narrative or lay highlights or arrows pointing out the next steps that will be taken when the next section of the video begins. I've used this technique when faced with explaining complex dropdown menus or previewing a series of steps. It ends up looking seamless because you are taking a shot of the screen right where you cut it, so the video picks up exactly in the same place. the key is to make sure you put a full sized version of the image in.
That will work! Thanks!
No problem. if you want to get fancy you can overlap by a little on each end and have the image fade in and out - it allows you to have a little more wiggle room and can make it a bit smoother.
