Installed my old Elements 7 on Windows 10. Slide/video project went OK, but I can't record it. Then a window pops up with a link to an encoder webpage, that just shows a 404 error. I did pay and register for this way back and still have the box. What can I do?
LB
I can't guarantee that 8 year old program will work on Windows 10 64-bit, Elisabet. But, if you are having problems, it might resolve things to run the program in Windows 7 Compatibility Mode.
Also, the program may need to activate some components that are no longer possible to activate. If that's the case, try downloading and installing the free trial of version 15. It may install the components version 7 needs.
Beyond that, what do you mean by "I can't record it." What are you trying to record?
By "I can't record it", I mean that I can make the draft copy, and I can
save it, so that I don't lose the draft frames while I'm working on it, but
can't save the video at the end, so that I can watch the whole thing on my
computer and/or burn it to a DVD for my family.
Thank you!
LB
In a message dated 12/28/2016 1:24:46 P.M. Eastern Standard Time,
forums_noreply@adobe.com writes:
Premiere El. 7 on Windows 10
created by Steve Grisetti
(https://forums.adobe.com/people/Steve+Grisetti) in Premiere Elements - View the full discussion
(https://forums.adobe.com/message/9227722#9227722)
I'm still not sure what you're saying, Elisabet. I've never heard of making a "draft copy" of a video.
Are you saying you can't output a video? What do you see if you select Export & Share/to Computer with the 1920x1080 resolution and MP4 output template?
Thank you Steve. When I say "draft", I mean the process of putting the
photos & videos together and add the effects and transitions, and you have a
small low resolution window to see what you are doing. (Sorry, I am not a
technical person, and not accustomed to the language used.)
Yes, I meant that I couldn't output the video. After "share" and choosing
MPEG, I could not save (I mean the lower-right "save" button, I don't mean
the save button at the top). A new (never seen) small window comes up,
which tells me to save the serial number to a linked webpage it provides, and
that webpage is not valid anymore, error 404. I wish they could have just
said that the version 7 can not be made to work anymore. I wasted a lot
of time. I think I will have to buy the new version 15, and hope that I
don't have to redo the work I put into the video.
I appreciate your effort, Steve. Thank you.
LB
In a message dated 12/28/2016 9:01:57 P.M. Eastern Standard Time,
(https://forums.adobe.com/message/9228471#9228471)
I'm sure you will find version 15 will remedy your issues, Elisabet.
I suppose I should uninstall the Prem. El. 7 before installing 15. What
happens to my "draft" work-in-progress video on Prem. El. 7 then? Does it
stay? Will the 15 software recognize it and can I finish it in 15?
LB
In a message dated 12/29/2016 8:26:08 A.M. Eastern Standard Time,
(https://forums.adobe.com/message/9228906#9228906)
You can not finish your version 7 project in version 15. In fact, trying to may corrupt the file and make it unusable.
Though as I've said, installing version 15 may "fix" version 7 so you can complete your project. Otherwise, the best move is to start fresh in version 15.
Steve,
So, can I install the version 15 without un-installing the version 7
first? It may not "fix" my version 7. But at least I may be able to somehow
use them at the same time (minimize the version 7 project while working on
the version 15, so that I can see exactly what I did before in version 7).
It would help in making the new project, rather than creating and
calculating every tiny little thing again from scratch, it would save me a lot of
time. And then uninstall version 7 when I'm done with the project. What do
you think?
LB
In a message dated 12/29/2016 9:44:12 A.M. Eastern Standard Time,
(https://forums.adobe.com/message/9229012#9229012)
Each version is complete and independent. You can have several versions installed on the same computer.
Steve, I purchased Prem. Elements 15, in the hope that it would fix my El.
7 project (on my Windows 10), but it didn't. So now I'll have to start
over on El. 15. Sigh...
But thanks for your ideas and I wish you a Happy New Year!
LB
In a message dated 12/29/2016 5:30:37 P.M. Eastern Standard Time,
(https://forums.adobe.com/message/9229945#9229945)
Thanks for reporting back, Elisabet. Happy new year to you too!
