@hi there,
Anyone knows how to disable tab from tabbed panel when clicked on a button?
I noticed that my tab does turn gray/black when it was disabled/enabled unless i clicked on it.
How to make it refresh automatically when clicked?
Thanks...
code below:
var w = new Window ("dialog", "test", undefined, {closeButton: false});
w.alignChildren = "right";
var tpanel = w.add ("tabbedpanel");
tpanel.alignChildren = ["fill", "fill"];
tpanel.preferredSize = [350,300];
var general = tpanel.add ("tab", undefined, "Text");
var images = tpanel.add ("tab", undefined, "Images");
var buttons = w.add ("group");
buttons.add ("button", undefined, "close", {name: "ok"});
hide = buttons.add ("button", undefined, "disable 'Images' ");
hide.onClick = function(){
images.enabled =false;
w.show ();
What do you mean by 'How to make it refresh automatically when clicked?'?
Peter
hi.. sorry for the late response.
what i meant is that when i clicked on the disable 'Images' button, the image tab's text is still enabled until i clicked on it then it'll appear grey (disabled) state.
ideally the moment the disabled images button was clicked it should turn@ grey.
i'm using Indesign CS6.
Ok, I understand now and can reproduce it but have no idea how to get around it. Looks like a bug in CS6 to me. In CC2017 it works fine, must be one of the very few (ScriptUI) things that got better after CS6!
Peter
noted.. Thank you
Hi eboda_snaf,
As often with ScriptUI this is a redraw issue. In CS4-CS6 the 'tab' widget—which by the way is a formal Panel instance—doesn't gray its label out when the enabled property changes. So you need to help it a bit. An option would be to hide() & show() the whole TabbedPanel component but that might be unnecessarily heavy. I found that temporarily changing the label (text) does the trick.
Best is to ‘prototype’ that tool:
Panel.prototype.refresh = function( t)
// Stupid op to force the tab to redraw.
this.text = (t=this.text) + '|';
this.text = t;
Then, in your code, just add images.refresh(); after disabling/enabling.
If this doesn't work, use tpanel.hide(); images.enabled=false; t.panel.show(); instead.
Marc
Hi, I Just Modify the Hide.onClick Function, Now it can Enable and Disable and Vice Versa :
if(images.enabled== true) {
hide.text = "Enable Images";
}else{
if(images.enabled== false) {
images.enabled=true;
hide.text = "Disable Images";
