Buenos días mi problema es el siguiente, importé fotos a Lightroom de una sesión importante y el programa las ha desaparecido de la carpeta donde estaban , osea si las puedo ver en Lightroom pero en la carpeta donde estaban no hay nada, tengo miedo que se eliminen de manera permanente, es la versión CC 2015.8. Quiero que vuelvan a la carpeta inicial. Espero sus respuestas. Gracias
Good morning my problem is the following, I imported photos to Lightroom from an important session and the program has disappeared from the folder where they were, if I can see them in Lightroom but in the folder where they were there is nothing, I'm afraid they will be eliminated Permanently, is the CC version 2015.8. I want them to go back to the home folder. I await your answers. Thank you
You probably imported using 'Copy' and LR moved them to the loaction that was set during the import.
Right-click on a photo (or on a folder in the folder panel) and select to show its location in explorer/finder.
If you need to move them, move them from within LR.
Thanks for your answer, I do not know the truth, but in the LR folder it is sorted by date and I find the images easily. Thank you. Blessings
This definitely sounds like LR's default when using 'Copy' in Import.
From where did you import them into LR? From a camera memory card inserted into a card reader or by connecting the camera directly to the computer? Did you first copy them from a card or camera to a folder on your computer?
Do you still have the memory card with the images still on it?
Hi, how are you? First copy the SD memory of the camera to a folder on the computer and just from the computer folder import them to LR
If you already copied them to your computer, you probably want to select 'Add' in the import dialog next time. This will leave the photos where you did put them.
