1
How to save slices in Photoshop CC (up to date version)
Jan 06, 2017 Jan 06, 2017
I must be missing something somewhere; I can slice an image but can not find a way to save the slices as individual jpgs.  Can anyone tell me how to do this in an up to date version of Photoshop CC?
[Here is the list of all Adobe forums... https://forums.adobe.com/welcome]
[Moved from generic Cloud/Setup forum to specific Program forum... Mod]
132.4K
Community Expert , Jan 06, 2017 Jan 06, 2017
File>Export>Save for Web (Legacy)
Adobe
Contributor ,
May 04, 2017 May 04, 2017
How do you export ONLY the selected slices? Didn't there use to be a All, Current, Selected, None... type option for exporting slices. I have an image with two slices in it, but it exports all the auto-slices too...
May 12, 2017 May 12, 2017
I am on Photoshop CC and for me it is when I get to the Save As screen where I navigate to the folder to save in. At the very bottom of that dialogue box is an option called "slices". The options are all slices, all user slices, or selected slices.
Contributor ,
Jun 01, 2017 Jun 01, 2017
Yes, I was looking for it in the Adobe Save for Web window, and not the actual Finder window where you choose location. Seems strange that the place to select the Slices is there and not in the Adobe window.
Jan 06, 2020 Jan 06, 2020
But This Method Now Gives an Eroor
Jan 07, 2020 Jan 07, 2020
yes, ends with error and the error report says it doesn't know why
Many thanks; I had tried something like this before but did not get a result at the time.  However, there is a problem; the master file type is jpg and I have selected jpg as the output file type but the sliced images are gif.  I've tried several times to change this but the sliced files are always gif.  Any further suggestions would be appreciated.
you can change the filetype of every single slice. Please be sure to choose the right file extension for every single slice as showed in the pic. Hope this helps.
Jan 07, 2017 Jan 07, 2017
Italosan; Many thanks for your information, I did eventually succeed with your guidance.  However, I found it a relatively convoluted procedure.  I don't know what Adobe are about here; what I wanted to do is readily available in a very straightforward manner in CS4 (which I still have) using the "Save for Web and Devices" function.  This is far simpler to use than the methods available in CC.  However, without your help I would have just given up before finding this out, so once again thank you.
Nov 27, 2017 Nov 27, 2017
I had this problem and fiddled around until i had a solution.  Not an ideal one but it worked.  On a fairly clean install I had my image divided into a number of slices (6 in my instance).  I opened the Save for web dialog and then holding the 'alt' button, I reset the dialog to default settings and then on saving it saved all my slices as jpegs.  I hope this works for you.
Clivewa, I'm glad to have been helpful in some way. Yes now it's a very complex process but you should consider the "export as..." as the main way to export pieces of images for the web who is now based on layers instead of slices.
The "slicing" is nowadays a useless waste of time, this is why I suggest you take a look at "export as..." who combined with the right use of layers it's a big timesaver
Cheers
Jan 08, 2017 Jan 08, 2017
Slicing is a lot simpler than layers for making HTML emails where we still have to use tables for early email clients.
May 09, 2018 May 09, 2018
Export as doesn't recognize slices. The question was how to export a single slice without having to go through all the menus to get to "save for web/legacy". Naturally Sketch is the better tool for anything UI/Web, but we sometimes still have to create image heavy emails etc in photoshop. Would be nice to find a quicker process in photoshop for exporting a specific slice.
Dec 22, 2019 Dec 22, 2019
this is nuts, take a well functioning process and make it disappear. image, make slices to align with the email design, save.
Jul 27, 2021 Jul 27, 2021
Hi, i keep getting an error when i go to save slices, what can i do to resove this?
