Playhead playing at 0.5 speed. HELP?
Jan 06, 2017 Jan 06, 2017
I'm quite new to after effects so i'm hoping I'm just being stupid and this is an easy fix. After Effects has been running fine up until yesterday where i changed a few settings to help my preview run nicer. Whenever I now try to preview my work the playhead moves at 0.5 speed. The area above the playhead, which is usually green, is blue as well. Please help.
specs
MacBook Pro early 2015
2.9 GHz Intel Core i5
Memory 8 GB 1867 MHz DDR3
running 2017 after effects
484
LEGEND , Jan 06, 2017 Jan 06, 2017
you can reset your preview panel here:
after your reset your panel, check again and show us a screenshots of what it sayes in the info panel about your playback
that's not related. blue means the frames are stored to disk and Ae will now save them to RAM instead of re-render them all o
Change it back.
I've changed everything back (apart from emptying cache) and it's still going at half the speed
that's not related. blue means the frames are stored to disk and Ae will now save them to RAM instead of re-render them all over again.
you should read here about what to expect when playing back in After effects:
Preview without rendering in After Effects
watch this:
and this:
After Effects CS6 Preview panel
and comeback if you still have questions.
THANK YOU SO MUCH, the play head is going at normal speed now. How do I switch the color back to Green??Screen Shot 2017-01-06 at 20.44.51.png
green means the preview is in RAM. blue means it's in disk. don't worry about it
here's a nice tutorial about it:
Learn how RAM and disk caches are used to save time in Adobe After Effects.
Jan 07, 2017 Jan 07, 2017
ok thanks
