Select and Mask issues with refine edge brush
Jan 06, 2017 Jan 06, 2017
Hello,
Yesterday i struggled for an hour trying to use the new select and mask tool, specifically the combination of smart radius and refine edge tool. When I have the 'plus' selected and try to "add" more areas in the selection, it was instead "removing" areas from the selection. I never had this issue with the refine edge tool. It worked like a charm. Please advise.
1.2K
LEGEND , Jan 07, 2017 Jan 07, 2017
Hello,
we don't really know for sure when Adobe put Refine Edge back into Photoshop as it wasn't exactly well publicised and so it is possible CC2015.5 doesn't have it. CC2015.5.1 most definitely does have it though. You need to check exactly what Photoshop version you have by going to the Help menu and clicking on 'System Info'
A dialog will appear. The top line gives your Photoshop version
In this case it is
Adobe Photoshop Version: 2015.5.1 20160722.r.156 2016/07/22:23:00:00 CL 1083377  x64
If tha
Adobe
Hi kushalb62902501 ,
first of all can you please check if you have the "+" sign active and the "sample all layers" inactive? Furthermore can you please check if any of your modification keys (alt or ctrl) are working correctly and are not "stucked"?
The only thing which I believe I didn't uncheck was the "sample all layers". Do you think that could be the problem?
If you are having problems with Select and Mask you can still use Refine Edge
A Nice video showing the use of Refine Edge with the Clone Stamp tool
I am not seeing any refine edge tool. I am using CC 2015.5 and following the above video, when I hold the "shift" key and choose "select and mask" from the select menu drop down, it still opens the "select and mask" tool and not the old "refine edge" tool.
Hello,
In this case it is
If that is not your version use the desktop app to update or in Photoshop under Help click on the 'Update' option. It is well worth having the update as there were quite a few bugs in earlier versions of CC2015
Once you are sure you have the final version of CC2015.5.1 you might like to look at my posting from October last year
Refine Edge has Returned
You may like to consider moving to CC2017 as it also contains Refine Edge.
