New master created from an existing master is not editable; objects from the old master are not positioned correctly, and I am unable to select them in order to make needed edits. Would one of you please show me what is going wrong here.
You need to go to the master the new one is based on and make the change there. Or just override them.
Would you please post the name of the program you are using?
The Forum Lounge is not for technical help, please provide the name of the program you are using so your message may be moved to the correct program forum
Sorry, this was intended for the inDesign forum.
jwc
Which version of InDesign and OS?
Using inDesign 2017.0 in IOS el Capitan 10.11.6.
