I stretched the square into a rectangle, but now I want to use it as a square again. No matter what I do, I can't seem to get it back to its original shape.
How do I "reset" it back to default?
when you tap on the shape, you should be able to change the aspect ratio with the slider back to square. It'll snap.
Thank you so much!
Hi Night shade,
Make the rectangle relatively large by pinching with two fingers. Then grab the sizing arrow at the bottom, and slowly drag it back and forth. A series of ruler lines appear to show the range, and if you drag the slider to the middle of the range, it will "snap" to the center, which is square.
The reason for making it large first is so that you have a wider range, giving you a better feel for the spot where it snaps.
Disclaimer: this might not be the right or official way, but it works. Frankly, I'd think something like double tapping the slider, or press and hold, could reset it. But I've found no such thing.
Mike
