Hi there, a few odds & sods:
1. I installed some plug ins which show in CC, Adobe Ext manager etc. One is " OmniSuite After Effects " ,
it shows live, enabled in both but nowhere in Photoshop > Windows> Extensions, After Effects at bottom of layertc or anywhere else I can see?
(I checked the listings in Help> System> Extensions and it's not listed as a failed to load, the ones that failed show as failed)
Any insight is appreciated, I'm sure it's user issue
2. I know it's not your software but has anyone out there used the Fractus plugin?
plugin Fractus Richard Rosenman Adobe Photoshop
Fractus - Richard Rosenman Advertising & Design
or another recommended plug in to make decent fractal imagery in Photoshop?After four hours, I can only make a monotone red square.
Any image I process with the filter makes the same red square??
By all accounts its a fantastic plug in, it is my method or my settings are way off.
...any insight or direction is appreciated
3.Finally, PS no long supports Pixel bender, the aforementioned Omnisuite plugin has a quasi function pixel bending fx, but I like to have a back up plan, assuming I cant get the OMniSuite working, can you suggest another or software to achieve similar results to the old Pixel bender app??
I love PS and dream a new image every day, it's like being a kid again ... immense fun -
Cheers
Rodger
PS - Got Fractus working - its deadly - one has to select the image as source color from a lower right drop down menu.
FYI ...I rechecked - Help> Sys and OmniSuite is not listed as a loaded plugin but not listed as failed but CC & the ext manager say it's active and loaded.
