I'm Currently creating an intro and the song was a little longer than I made the video, so I took a screenshot of the last frame and had it scale out and the opacity slowly go to zero. If you look close enough you can see the little black border of where the background for the composition is. How would I be able to kind of blot/spread the color from the smoke effects to the black comp? Please help as I am a YouTuber and need this intro asap. Thanks!!
you don't have to do it that way. you can trip+duplicate (Ctrl+Shift+D) the video at that frame and freeze frame (right click ->time->freeze frame)
show us what you are doing. it's not quite clear. if you want a color to be placed below your footage you can add a solid layer and use the eyedropper to sample any color you want.
Hi KyleC,
Did you ever solve this problem. How about Roei's response? Did it hellp you solve your problem?
Kevin
